Honda S2000 Honda S2000
Oil filter relocation using factory oil cooler. Pictures inside.
Old May 21, 2007 | 10:00 AM
MidwestAutoWorks's Avatar
Default Oil filter relocation using factory oil cooler. Pictures inside.
I was just working on my s2000 and I am about finished with the oil relocation aspect of it. Here are pictures.
And the reason for doing this.
Old May 21, 2007 | 10:12 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Oil filter relocation using factory oil cooler. Pictures inside. (MidwestAutoWorks)
It's not a cooler, it's a strainer.
Old May 21, 2007 | 10:17 AM
Default Re: Oil filter relocation using factory oil cooler. Pictures inside. (Mr. Projekt)
Its a wata coola. gatorade/h20/gatorade/h20
Old May 21, 2007 | 10:24 AM
Yosshaa's Avatar
Im cruious to see how (if) this will effect your oil pressure
Old May 21, 2007 | 10:32 AM
Default Re: Oil filter relocation using factory oil cooler. Pictures inside. (Yosshaa)
Im guessing not a whole ton since I am only about 12 inches away from the original spot.
Old May 21, 2007 | 10:40 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yosshaa &raquo;</TD></TR><TR><TD CLASS="quote">Im cruious to see how (if) this will effect your oil pressure</TD></TR></TABLE>
I did an install of an Earl's cooler with about 40" of total line for the feed and return, and oil pressure fluctuated about 3-5 psi more than normal. Didn't affect the solenoid for VTEC engagement. The lines themselves held more oil than the actual cooler.
Old May 21, 2007 | 10:41 AM
* B A N N E D *
I noticed you banged your crossbeam a little taking out your motor?
Old May 21, 2007 | 10:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">I noticed you banged your crossbeam a little taking out your motor? </TD></TR></TABLE>
Im not worried about VTEC solenoid pressure my EMS controls that now.
Actually I have a comptech supercharger and that is required to get it to fit correctly.
I am going to fab up a cover for that whole length
Old May 21, 2007 | 11:00 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">
I am going to fab up a cover for that whole length</TD></TR></TABLE>
Why do you still have your A/C compressor if you have no lines?
Hope you like me picking at your project, I'm kinda bored this morning.
Old May 21, 2007 | 11:10 AM
Was going to take that out, but i was unsure if that would hurt anything.
It would be nice to have one belt. Crank and alternator
Old May 21, 2007 | 11:19 AM
* B A N N E D *
Like this? Part numbers:
Bando 6PK1145
Goodyear 6PK1005
Goodyear Gatorback 4060450
For the Bando, you can use 6PK1150 if there's too much tension with the ~45. 5mm difference.
Old May 21, 2007 | 11:23 AM
great thanx!
any way to do it without all the other crap just straight alternator and crank pulley
Old May 21, 2007 | 11:25 AM
* B A N N E D *
What about the water pump?
You'd have to take that fat-*** pulley out of the way, then measure out how long your belt needs to be. The alternator bracket is slotted, so I guess you could use that to tension your belt. I haven't had a need to try it; without the AC compressor dragging, it feels like a new lighter flywheel.
Old May 21, 2007 | 11:52 AM
durr i forgot about the water pump, off to the store to find some belts.
Im sure with the AC compressor off, the fidanza flywheel, the turbo kit, and the 4.57 gears, this thing is going to be sick
Old May 21, 2007 | 11:53 AM
* B A N N E D *
Dyno plots, time slips =
Old May 21, 2007 | 12:27 PM
cant wait, just waiting for my ems to get here
Old May 21, 2007 | 01:07 PM
Sean Juan's Avatar
Looks pretty good. I would be scared to mount it right there though.
Old May 22, 2007 | 05:01 AM
Default Re: Oil filter relocation using factory oil cooler. Pictures inside. (Sean Juan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean Juan &raquo;</TD></TR><TR><TD CLASS="quote">Looks pretty good. I would be scared to mount it right there though.</TD></TR></TABLE>
Why is that?
NOBODY IN THE CITY OF MILWAUKEE CARRIES GOODYEAR BELTS. Not even goodyear.
durrrrrrr
Old May 22, 2007 | 05:09 AM
Any idea what car those belts come off of?
Old May 22, 2007 | 08:52 AM
* B A N N E D *
Hhahahahhaa. Try Bando? They're actually much better than the Goodyears. To answer your question, I have no clue what car they come off of.
Old May 22, 2007 | 07:17 PM
Eyal 951's Avatar
why did you mount it right side up like that? its just gonna spill out oil everywhere when you pull it off. Flip it over.
Old May 22, 2007 | 07:32 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Oil filter relocation using factory oil cooler. Pictures inside. (Eyal 951)
hows the mani/turbo placement in relation to the oil lines?
Old May 22, 2007 | 09:46 PM
m R g S r's Avatar
I'm not understanding this....those are coolant lines right? How does the oil get to the filter??!
Old May 23, 2007 | 04:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eyal 951 &raquo;</TD></TR><TR><TD CLASS="quote">why did you mount it right side up like that? its just gonna spill out oil everywhere when you pull it off. Flip it over.</TD></TR></TABLE>
Actually gravity takes most of it back down and there will be minimal oil spillage.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">I'm not understanding this....those are coolant lines right? How does the oil get to the filter??!</TD></TR></TABLE>
The picture does not have the oil lines yet, Im still waiting on my bulkhead fittings from summit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">hows the mani/turbo placement in relation to the oil lines?
Far enough away not to cause any heat issues
Old May 23, 2007 | 05:55 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Far enough away not to cause any heat issues</TD></TR></TABLE>
i would still consider some SS lines either way for peace of mind...
