UK EP3 CTR Brake reccommendation
Old May 21, 2007 | 09:45 AM
hc99si1's Avatar
Default UK EP3 CTR Brake reccommendation
Hi Folks, the time has come to change the pads. What pads are you guys running and any personal reccommendations you can give?
The discs are OEM btw.
Thanks.
Old May 21, 2007 | 01:35 PM
BarracksSi's Avatar
Do you road race or autocross the car?
Old May 22, 2007 | 01:52 AM
hc99si1's Avatar
Only for fast road use.
Old May 22, 2007 | 10:28 AM
BarracksSi's Avatar
I autocross occasionally, and have my eyes set on doing a trackday sometime, so I have Cobalt GT-S pads that I use daily on the car. I also have a new front pair of their Spec-VR pads that I'd like to use on a track.
The GTs are good for their intended use -- grabby, with decent modulation, and definitely better heat tolerance than stock. I have to be aware of their need to heat up a bit when the weather's cold, though; their operating temperature range starts around 70 degF. If I've been driving down the highway in winter weather, for example, and decide to take an exit, I can feel that they need a second of easy braking to warm up and work as well as they should.
They perform well, no doubt. They're also noisy and really dusty. If I didn't autocross, I'd use something milder and more temperature-friendly instead.
Old May 23, 2007 | 11:09 AM
hc99si1's Avatar
Thanks for the information, I'll have a closer look at them. The noise and dust isn't a huge issue as long as they perform.
Old May 23, 2007 | 11:14 AM
BarracksSi's Avatar
There are also several companies that are coming out with carbon-ceramic pads, which appear to promise a wide temperature range and good modulation. I'll probably be trying that route after I'm done trashing the ones I've got.
baggelis
Honda S2000
34
Feb 22, 2009 10:19 PM
shivic
15
May 16, 2008 07:01 PM
civicmatt
Oct 15, 2002 03:12 PM
rus
Oct 5, 2002 07:39 PM
Sam
Nov 27, 2001 04:35 PM
