Dash swap ---> Turn signals dont work
I have just been doin a black interior swap and everything works liek it should except the turn signals. The hazards work when I turn them on, so the relays and fuses are still good, but when i try to use my turn signals they dont come on. The steering column is the same one that was on it originally and everythign worked fine.
Someone please give me some insight, none of my acura technician friends know why it wont work either.
this is one of those problems where the only thing you may be able to do is trace the wires and make sure everything is connected(and by connected I mean not just plugs connected but test the wires with a multimeter and make sure they are functioning). I'd start by checking to make sure all of the plugs in that area are secured and all the grounds are tight. If you dont find anything grab a wiring diagram and start tracing and testing those wires... it's not fun and yes it takes a while, trust me I know how it feels but for something like turn signals it pretty much has to be done. goodluck
