i need help for my 89 hatchback with ZC sohc swap!!
Old May 21, 2007 | 08:38 AM
zcsport's Avatar
Default i need help for my 89 hatchback with ZC sohc swap!!
first of all my car won't start and i thought it was the battery and i replace them but the problem still there..and i had a friend push my car to turn on but it didnt turn on too..but after 3 miles of pushing my car it turns on again with up and down idle and white smoke comes out of the exhause!!and when i was driving it is hella wired cus when i tap the gas pedal the RPM drops down and the car would stall just like that!!there was back fire comes out of my exhause too!!when i turn the key to *ON*..i heard some clicking sounds from somewherewhen i try to turn on my car..if you think u know sumthing plz give me some advise..thank you!!
Modified by jdmhbef at 10:02 AM 5/21/2007
Old May 21, 2007 | 09:02 AM
Jerms's Avatar
check the ecu, sounds like the dizzy , ignition
Old May 21, 2007 | 09:04 AM
zcsport's Avatar
Default Re: (Jerms)
when i turn the key to *ON*..i heard some clicking sounds from somewhere when i try to turn on my car..is it the main relay cause there was no fuel goes to the engine datz what i think!!
maiden424
Nov 19, 2012 09:30 AM
91h@tch
Aug 20, 2009 10:23 AM
ef_zc
14
Jul 4, 2008 01:55 PM
hondacivic90zc
11
Apr 17, 2007 04:42 AM
Gumbey75
Feb 14, 2005 09:32 AM
