itr valve spring and omni power valves...good to 9000rpm?
Old May 21, 2007 | 07:03 AM
the.hamburglar's Avatar
Default itr valve spring and omni power valves...good to 9000rpm?
thinking about using this combo. would it be efficient to 9000 rpm?
Old May 21, 2007 | 05:17 PM
Default Re: itr valve spring and omni power valves...good to 9000rpm? (the.hamburglar)
ttt
Old May 21, 2007 | 05:34 PM
doood's Avatar
been there done that
what cams?
Old May 21, 2007 | 10:22 PM
Default Re: itr valve spring and omni power valves...good to 9000rpm? (doood)
itr
Old May 21, 2007 | 10:28 PM
im thinking about picking these up:
http://cgi.ebay.com/ebaymotors...=true
can i use the itr springs, keepers and retainers with these valves?
Old May 22, 2007 | 09:40 AM
9200RPM's Avatar
correct me if im wrong, but itr cams stop making power around 8400 rpms...there would be no reason to rev the engine to 9000 rpm
Old May 22, 2007 | 04:55 PM
Default Re: itr valve spring and omni power valves...good to 9000rpm? (TurboB16aEG)
why do stock itr's run to 8700 then?
Old May 23, 2007 | 06:20 AM
9200RPM's Avatar
just because the rev limiter is set at 8700 doesnt mean it makes usable power that high...I guess the best thing to do is put your car on a dyno and see where the power peaks...ps..you dont have to be an *** about it, you asked for help and someone answered
Old May 23, 2007 | 04:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">why do stock itr's run to 8700 then? </TD></TR></TABLE>
hows that being an ***? all id like to know is if i can use itr spring and retainers and keepers with omnipower valve?
Old May 23, 2007 | 07:53 PM
9200RPM's Avatar
I guess I'm a little defensive tonight...I thought I picked up some scarsasm in that post...my bad man...I dont see why you couldnt use that setup...the valve stems should be the same design as the stock on the retainer side..
Old May 23, 2007 | 08:03 PM
ya thats what i was thinking too, thanks for the assurance. i think im only going to rev it to 8500 now. no girdle
Old May 23, 2007 | 08:19 PM
ITR#132's Avatar
My ITR stock revlimiter was at 9100rpm. Tach is off.
GReddy SI
17
Nov 8, 2009 12:51 AM
nonsense
11
Mar 13, 2008 05:13 PM
A2_8U
Dec 12, 2006 11:48 AM
theslugbug
14
Jun 5, 2004 10:05 PM
ninjaman
Jul 17, 2001 01:43 PM
