brake bleeding on 94accord ex with abs?
Old May 21, 2007 | 03:32 AM
98accordv6green's Avatar
Default brake bleeding on 94accord ex with abs?
What is the proper way to bleed a brake system with abs system?
Old May 21, 2007 | 06:14 AM
JimBlake's Avatar
Default Re: brake bleeding on 94accord ex with abs? (98accordv6green)
The '94 ABS system has it's own reservoir & bleeder valve.
First, bleed the main brakes. I don't know the bleeding order, but I'm pretty sure someone has posted it around here. Search, but the order is specific for each generation of Accord.
Then bleed the ABS. I've posted instructions for that, either here or in the Integra forum (probably both). Look for 5th-gen instructions, because beginning in '98 there's a completely different ABS system.
Old May 21, 2007 | 07:06 AM
The-Kid's Avatar
I had a whole thread about it. Go to search and type in " ABS bleeding on 96 Accord " its in the archives by now.
Thats if you want to bleed the ABS. If you want to bleed the brake line. Do as if there wasn't any ABS on the car.
kjmoy
Dec 10, 2007 02:38 AM
bonh
Jun 28, 2007 12:15 PM
Kid1320
Jun 14, 2004 03:44 AM
oioioi
Jan 23, 2003 02:56 PM
