Running eg radiator
Question about running half-sized eg radiator.
So obviously it doesn't fit, but i noticed that it only sits about 3/4 of an inch higher than the stock radiator, when comparing the hight to the radiator t-bar. I was wondering if anyone kept the stock crossmember and used a eg radiator without the "gangster lean" by just cutting the webbing off the hood from that section? It looks like it would work.
Any input would be great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcars.com »</TD></TR><TR><TD CLASS="quote">Without the lean, more clearance is needed than what you can get from removing the webbing from the hood.</TD></TR></TABLE>x2 you better start feeling the lean or new xmember...gl
to bad your not a local rcautoworks has done this a couple times works great http://www.rcautoworks.com/Zac%27scar.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan »</TD></TR><TR><TD CLASS="quote">Alright. I think i'll do some mods to the stock crossmember to better fit the half-sized.
I'm 99% sure i can get this to work haha.</TD></TR></TABLE> yah you can notch it out, but when people do that you are just weakening your crossmember and also this makes the radaitor more available to road debris...gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY »</TD></TR><TR><TD CLASS="quote"> yah you can notch it out, but when people do that you are just weakening your crossmember and also this makes the radaitor more available to road debris...gl
That is true. I won't be removing much though, and i will re-enforce it.
Thanks for all the input
</TD></TR></TABLE>That is true. I won't be removing much though, and i will re-enforce it.
88 rex
Sep 8, 2005 04:37 PM
