Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
cluster light issues : Maint. Trunk, and Battery all on
Old May 20, 2007 | 09:17 PM
phpCypher's Avatar
Default cluster light issues : Maint. Trunk, and Battery all on
2002 Honda Civic 66k
tested the battery, works fine (12 volts off, 14 on), yet light is still on
trunk is closed, light is still on ( alarm still goes off when the trunk is opened, so it is NOT a faulty switch/sensor)
Cluster makes a weird noise as the fuel gauge moves up/down when key is turned to on position. (I read somewhere gauges for 2002 were under TSB #1002 : http://www.carcomplaints.com/H...shtml )
ECU is throwing code P0600 aka "Multiplex Control System Troubleshooting"
Car has aftermarket stero as well as alarm, both functioning perfectly fine.
I would like to know where to begin trouble shooting this ? Will multiplex fall under this TSB ?
I know short/problem lies between/within multiplex/cluster/ECU.
I have no experience with multiplex systems at all.
I hope I've come to the right place .... hope you guys can help
Old May 30, 2007 | 01:26 PM
ejackson001's Avatar
Default Re: cluster light issues : Maint. Trunk, and Battery all on (phpCypher)
I'm also having alarm issues (on a 07 civic ex). I'm being told that it is due to a faulty multiplex.
1clean01
Jan 18, 2015 04:25 PM
roachsboosted16
19
May 7, 2008 11:55 AM
mikeunreal2
May 29, 2006 01:38 PM
sshaikh01
10
Apr 16, 2005 11:44 AM
