91 Civic with a fresh B20 swap is only getting spark too two wires.HELP?
Old May 20, 2007 | 09:00 PM
shinineg6's Avatar
Default 91 Civic with a fresh B20 swap is only getting spark too two wires.HELP?
I just put a B20 low intake into my Ef. Previously it had a B20 V-Tec and then the car was sold. I just purchased the car back about a week ago and the guy who i had originally sold the car to had gotten state reffed so he put a single cam v into it and had it all converted to obd-1. Now that the new swap is in the motor runs but only runs on two cylinders. it idles and everything it just sounds like it has some crazy cams. the compression is fine and the distributor is brand new along with pretty much everything else. At this point i am just mind boggled. Any help please
Old May 20, 2007 | 09:11 PM
shinineg6's Avatar
Default Re: 91 Civic with a fresh B20 swap is only getting spark too two wires.HELP? (shinineg6)
anyone?
Old May 20, 2007 | 09:20 PM
shinineg6's Avatar
HELP
Old May 20, 2007 | 09:26 PM
shinineg6's Avatar
bump
Old May 20, 2007 | 10:19 PM
shinineg6's Avatar
bump
Old May 20, 2007 | 11:11 PM
shinineg6's Avatar
Old May 21, 2007 | 07:11 AM
mahatma's Avatar
i didn't know a motor could run on only 2 cylinders!! how do you know this is happening?
Old May 21, 2007 | 07:22 AM
white90rexsi's Avatar
Default Re: 91 Civic with a fresh B20 swap is only getting spark too two wires.HELP? (mahatma)
When you say its only getting spark to 2 cylinders I assume you hooked up a spark tester to each cylinder 1 at a time and only 2 are firing? Just because the distributor is new does not mean its good. Is it aftermarket? Take a look at your cap and rotor. If everything is good with the distributor/cam sensor I would go after the wiring next.
Old May 21, 2007 | 09:02 AM
shinineg6's Avatar
Default Re: 91 Civic with a fresh B20 swap is only getting spark too two wires.HELP? (white90rexsi)
i tried all of the above and the cap and rotor are brand new and still nothing
Old May 21, 2007 | 11:15 AM
HF2ZC's Avatar
did you hook up a noid light to the injectors to make sure that all of them are firing properly?
foowitdaredek
Feb 9, 2016 07:06 AM
syobwoc sallad
Mid-Atlantic (Sales)
Jun 11, 2014 10:38 AM
Fibercation
Apr 30, 2014 02:13 PM
dreadhead89
Dec 7, 2009 06:05 PM
smokez187
May 10, 2007 01:20 PM
