radiator fan
Old May 20, 2007 | 07:55 PM
getsuummm's Avatar
Default radiator fan
I have a 92 prelude with an h22a swap. The radiator fan has never worked when it is supposed to. So I kinda made it so that it worked indepently through a switch. I tried to hook it up to the ignition fuse in the fuse box under the hood and it still turns on with the ignition off. I want it so that it turns off whenever the car is off. I don't want to forget to turn it off and it drain my battery. Just wondering if there was another way to do that. Thanks in advance for any positive input.
Old May 20, 2007 | 08:07 PM
zirac50's Avatar
Default Re: radiator fan (getsuummm)
It's sounds like you did not hook it right and connected directly to the battey that's is why even you turn your ignition off fan still running. Check you wiring again make sure you got to read the schematic properly.
My prelude does same **** I only heard my fan turns on when I drove it 6hrs after that nothing I never heard my fan turns on again.. I did not bother about it. I thinks if the temp is below threshold to where the fan would turns on, the fan won't run.
Old May 20, 2007 | 08:51 PM
outlawstar27's Avatar
Default Re: radiator fan (zirac50)
i got the same problem. my radiator fan hasnt turned on and it seems like the car is hot but the gauge marks normal temp. well i grounded the ground wire from the fan and the other i hooked up to a fuse. the fan stays on even when theres no key. i need help too!
Old May 20, 2007 | 10:48 PM
SnlpeR's Avatar
use a relay to switch it on with the ignition wire
Old May 20, 2007 | 11:17 PM
zirac50's Avatar
Default Re: (SnlpeR)
when it turns on (when key is out) does it shut off after couple of mins? the fan is design to turns on/off intermittently even the engine is off and it's hot. I don't know how you guys do it so it's hard to tell cuz now it has different wiring setup. I would say leave the fan alone, until you are sure what is the problem y it's not turning on. There is a way on how to check fan switch on helms. check it out!
Old May 21, 2007 | 05:15 AM
mattsnooz's Avatar
Default Re: (zirac50)
You want it to run when your car is shut off though, for a bit sometimes. if your running hot, as soon as you shut down your fan won't work and you risk over heating as you stand.
the fan should be connected to a timing relay that allows it to stay on (when motor hot) for a couple minutes post shutdown
Old May 21, 2007 | 01:59 PM
getsuummm's Avatar
Default Re: (mattsnooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote"> You want it to run when your car is shut off though, for a bit sometimes. if your running hot, as soon as you shut down your fan won't work and you risk over heating as you stand.
the fan should be connected to a timing relay that allows it to stay on (when motor hot) for a couple minutes post shutdown</TD></TR></TABLE>
How would i connect it to a timing relay? I've never messed with it before.
Old May 21, 2007 | 05:26 PM
ray55346's Avatar
Default Re: (getsuummm)
Would like to clarify as it sounds like I have the same problem too... I think everyone is in agreement that the fan should either stay on or come on just after engine shutoff if cooling is needed.
However, my fan will sometimes come on 2 or 3 hours (or more) after engine shutoff. Certainly, the engine is cooled by then (air temperature below 50 degrees). While the engine is off and the car parked, the fan will just cycle on and off seemingly at random.
Is this what is happening with the other fan problems? And does anyone have any clue as to why this would occur?
Thx!
Old May 22, 2007 | 11:53 PM
zirac50's Avatar
Default Re: (ray55346)
If you guys have a situation like both fans come on when ac is on but radiator fan won't work independently this might help. I have not gotton a chance to do this on my lude but i will when i get a chance.
Old May 23, 2007 | 05:37 AM
spoolinlude's Avatar
I live under a rock
Just hook your "hot" wire up to the parking light switch on the dash fuse box, then you can turn your parking lights on to turn the fan on. Plus, you get the beep when you leave your lights on, so now you'll never forget to turn the fan off... its a cheesy way of doing it, but it'll work.... in the future, get a thermo-switch for the fan.
NAS95
Jan 15, 2018 01:51 AM
Sixx23
11
Feb 19, 2014 11:44 AM
Dekorum
10
May 2, 2012 08:15 PM
CivicSi95
May 30, 2010 04:15 PM
Nino_eg6
Jan 28, 2009 02:28 PM
