JDM front Question
I bought my R with the front already on it. The wiring was hacked to hell. does any one know what harness i can use for the head light harness. the conector is brown and is a 5 pin. ive got the headlight side of the harness, just looking for somthing i can use for the body side
if you want to hook it up right, you can get the custom harnesses that are already made to plug into the JDM lights. They aren't that spendy either.
headlight harness:
http://passwordjdm.com/Passwor....aspx
side marker/city light:
headlight harness:
...after re-reading your post, I'm not sure if those will work for you, or if that is the part you already have.
It sounds like you are looking for the plug that should have been in the car from the factory?
highroller54
Feb 13, 2007 08:29 PM
