For the life of me (88 door wire)
So I had to replace the drivers side door. I've just spent the last 1hr or so on my back under my dash tring to locate where the White wire clip goes. I've found the Orange one. I'm talking about the wire harness that comes from the door to the inside of the car. It has a orangish and a white clip (not sure if clip is the right word). Sorry I have no means of posting a clip. If anyone can help me out. (Chilton guide is of no help too)
You need to connect up the door harness? Look in the front of the door in between the hinges, there should be a rubber boot that covers the harness connector.
From the inside of the car you might have to remove the kick panel to find the harness, if the connector got shoved back in.
I can't find where the two (from the door) go back to. I found where the larger orange one goes but for the life of me I can't find the white connection anyplace.
Kyle700
Dec 10, 2014 11:32 AM
