transmission gsr or b16 for b20 motor
Old May 20, 2007 | 05:59 PM
mustang5.slow's Avatar
* B A N N E D *
Default transmission gsr or b16 for b20 motor
i keep hearing that a b16 transmission is the best out there
but gsr is the next step. is there a big nasty diference between the gsr and the b16. if so what is the difference.
i've been waiting for about a month to find a b16 transmission. and it doesn't come around, but gsr tranny are up like crazy. thanks guys for the info.
Old May 20, 2007 | 06:08 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: transmission gsr or b16 for b20 motor (mustang5.slow)
ITR tranny with lsd and the jdm final drive is probably the best oem parts tranny out there.
Did you try craigslist and ebay?
B16 shouldn't be that hard to find. A gsr will be comparable. Just as long as it's not an ls tranny.
Old May 20, 2007 | 06:09 PM
Ek Forever y0!
Default Re: transmission gsr or b16 for b20 motor (ek forever guy)
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
Ta-da.
Old May 20, 2007 | 06:12 PM
* B A N N E D *
ITR tooo toooo tooo pricey for me right now.
i just wanna get that b20 in my EG
so gsr are not that bad then right.
do you have any way of describing the difference in both the transmission.
Modified by mustang5.slow at 7:23 PM 5/20/2007
Old May 20, 2007 | 06:16 PM
Ek Forever y0!
other than showing you the mph limits of each gear, which can be found in the link I posted.
the gsr just has slightly longer 1-3rd gears, a longer 5th, and a differen't final drive.
The gsr will probably get 2-3 better gas mileage on highway.
Also the gsr might be less hectic depending on how finicky of a driver you are for daily driving.
Old May 20, 2007 | 06:24 PM
* B A N N E D *
gsr it is thank you my man>>
Old May 20, 2007 | 06:35 PM
doood's Avatar
been there done that
from a personal experience standpoint, 1-2 are a bit too long for my liking with a gsr. a b16 would fit me much better.
Old May 20, 2007 | 07:46 PM
djmatix's Avatar
i've got a b20 with a b16 transmission. It RIPS. I'd go with it for sure!
Old May 20, 2007 | 07:53 PM
MR.johnson's Avatar
Default Re: (djmatix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">i've got a b20 with a b16 transmission. It RIPS. I'd go with it for sure!</TD></TR></TABLE>
i bet it does
Old May 20, 2007 | 08:17 PM
djmatix's Avatar
Default Re: (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson &raquo;</TD></TR><TR><TD CLASS="quote">
i bet it does</TD></TR></TABLE>
come on, I know its non-vtec, but its a torqey fun little hatch to rip around in.
Old May 20, 2007 | 09:44 PM
* B A N N E D *
awh shiet.
now i want a b16 tranny. but all the shops around here sell them for 900 cold ones.
if you guys see one LMK i'll cough up to 700.$$$ but 900 is too rich. for my blood
Old May 21, 2007 | 05:01 AM
djmatix's Avatar
Default Re: (mustang5.slow)
Yeah, the gear ratio is whats so desireable about the b16/type-r transmission. 900 is a little steep if you ask me. One could by a type-r transmission for that much.
Old May 21, 2007 | 05:12 AM
Ep1dem1c's Avatar
I have a GSR Tranny in my EG right now with a B16 motor
The gears are much longer. The car is not as snappy as a B16 with a B16 Tranny. Its good for boost though... so it all depends on what you want to do with your car.
Old May 21, 2007 | 06:55 AM
nxvictim's Avatar
Default Re: transmission gsr or b16 for b20 motor (Ep1dem1c)
all i heard about the difference in the 2 trannys is how they are on the freeway or at high speeds, the b16 you ll be cruising at like 80 stuck at like 4500-4800 stuck in vtec that if u have vtec if not i geuss it doesnt matter but the gsr is wat im going with in my ls
Old May 21, 2007 | 07:10 AM
djmatix's Avatar
I personally love b16 gearing on boost. With nice tires, and a good tranny that can shift quick, you can really work people. It also helps when doing 40mph burnouts next to people that come up all hard blowing off or rasping like a ricer :-D.
Some people dont like how high it rides when crusing on the highway. I'm not familiar with having vtec that low so it was never a problem with me.
I had a little t25 at one point on my b16 and at high speeds it would build boost just while cruising.
Like Ep1dem1c said, its all about what you want to do with your car.
Old May 21, 2007 | 07:24 AM
92eg6's Avatar
?? If thats wut u like thats cool. Me personally would like to spool the turbo before having to shift..
Anyway long run is.. If you going to be driving in the street and plan on doing on racing on the track go with the b16.. If u drive alot on the highway and need to travel and commute. Go with the GSR.. Your 5th is longer and itll be nice not having to in vtec the whole time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">I personally love b16 gearing on boost. With nice tires, and a good tranny that can shift quick, you can really work people. It also helps when doing 40mph burnouts next to people that come up all hard blowing off or rasping like a ricer :-D.
Like Ep1dem1c said, its all about what you want to do with your car.</TD></TR></TABLE>
92eg6's Avatar
Anyway long run is.. If you going to be driving in the street and plan on doing on racing on the track go with the b16.. If u drive alot on the highway and need to travel and commute. Go with the GSR.. Your 5th is longer and itll be nice not having to be in higher rpms the whole time since b20s are for lower gears and make power thier
Old May 21, 2007 | 09:56 AM
* B A N N E D *
Default Re: (92eg6)
b16 it is...
if you guys run into one LMK&gt;
thanks for all the help full shared thoughts.
Old May 21, 2007 | 11:10 AM
VTECth1s's Avatar
honestly you will be satisfied with either tranny, I've had a, gsr tranny and a ls tranny case with ctr gears. Not a b16 tranny, But I would assume its slighty better due to the fact your at a higher rpm in every gear, allowing you to keep your power band up. I didn't like the gsr tranny as much, got bored of it. If your driving strictly street and barely any hwy driving then do the b16, if your going to do lots of hwy and street driving, then the gsr tranny would be best. ITR tranny is a different story but thats not the topic. But ultimately I would go with a b16 over a gsr, its slightly cheaper then a gsr tranny as well too.
Old May 21, 2007 | 04:25 PM
doood's Avatar
Default Re: (VTECth1s)
you will not be cruising in vtec if you have a b16 tranny unless you're above a certain throttle position
Old May 21, 2007 | 04:54 PM
slowex98's Avatar
I like the ctr trannies they have really short gears
Old May 21, 2007 | 05:03 PM
doood's Avatar
Default Re: transmission gsr or b16 for b20 motor (slowex98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowex98 &raquo;</TD></TR><TR><TD CLASS="quote">I like the ctr trannies they have really short gears
they are the same as itr tranny's
Old May 21, 2007 | 05:15 PM
del_slow420's Avatar
Default Re: (92eg6)
i have a cable b16 with my b20vtec i love it i wouldnt trade it for another b20 block
Old May 21, 2007 | 06:07 PM
* B A N N E D *
Default Re: transmission gsr or b16 for b20 motor (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
they are the same as itr tranny's</TD></TR></TABLE>
they are??
Old May 21, 2007 | 06:16 PM
doood's Avatar
yep
d16z6_b_pirate_13
Oct 30, 2008 10:00 AM
shuck21
Oct 27, 2008 06:09 PM
HighRevn
18
May 4, 2008 08:20 PM
DrGrEeNtHuMb
Mar 23, 2008 06:21 PM
norcalbayboy
16
Sep 17, 2007 07:42 PM
