Replacing Dash Lights. How?
Old May 20, 2007 | 05:40 PM
Boggy20's Avatar
Default Replacing Dash Lights. How?
The TCS (! in a triangle) and the TCS symbol do not light up. What do i need to do to get this fixed. What would result in this, (a short or something more serious?) Do i just go to the dealership? What provides the light to those symbols?
BTW I bought it used and its a '03 7th gen accord. Thanks.
Old May 20, 2007 | 05:47 PM
oem_certified_accord's Avatar
Default Re: Replacing Dash Lights. How? (Boggy20)
check fuses bro
Old May 20, 2007 | 05:51 PM
Boggy20's Avatar
Default Re: Replacing Dash Lights. How? (oem_certified_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord &raquo;</TD></TR><TR><TD CLASS="quote">check fuses bro</TD></TR></TABLE>
How do i do that?
Old May 20, 2007 | 05:58 PM
most likely under the hood in a little plastic black box with a pop off lid. should be in a top corner (most likely left) by your windsheld...and read the label and check for the light label you're looking for. it sounds like your saying hazard, but then again i dont know of a tcs because i'm 5th gen...but if ur just trying to get it to illuminate you may want to check the inside fuse box. located next to your clutch pedal (manny) or brake pedal (auto)
Modified by oem_certified_accord at 7:17 PM 5/20/2007
Old May 20, 2007 | 06:07 PM
Boggy20's Avatar
I see, wouldn't i just be able to take it to the dealership? What should I look for when I check the fuse?
Old May 20, 2007 | 06:16 PM
no dealership needed, this is a simple task my boy...let me try to help you.i'm looking at my 5th gen fuse box cover and the closest i see to what you're describing is...interior light, and lighting relay..look for those on your fuse box cover and pull then out when your fingers or needlenose pliers (but not while the key is in the ignition) and you should easily be able to tell if the fuse is blown or not.
Old May 20, 2007 | 06:29 PM
Boggy20's Avatar
And if it is? What would I do? Also, the interior lights wouldn't they ALL be out? Only ONE light doesn't work on the dash. Not all of them.
Old May 21, 2007 | 09:24 AM
like i said i'm 5th gen, just get a led kit for your dash buttons and kill 2 birds with a couple of dollars
hatchieg
Aug 8, 2009 08:32 AM
baginz
May 21, 2008 07:08 AM
jdadams12
Nov 3, 2005 04:31 AM
blaster834
Apr 28, 2004 02:17 PM
AK94GSR
Jul 11, 2003 02:22 PM
