Rear main seal or oil pan?
Old May 20, 2007 | 05:08 PM
1.8L_allmotormilitia's Avatar
Default Rear main seal or oil pan?
Does it look like my main seal is leaking or does it look like dirt/oil build up from the oil pan? This motor WAS a automatic jdm gsr motor.
Old May 20, 2007 | 05:20 PM
Old May 20, 2007 | 06:44 PM
ttt
Old May 20, 2007 | 06:45 PM
VTEC_PRODUCTION's Avatar
Default Re: (1.8L_allmotormilitia)
hard to say...wipe it clean and go from there...chances are its buildup...
Old May 20, 2007 | 06:49 PM
iowecharles200's Avatar
it looks like build up to me.
wipe it off and look. might as well replace the pan gasket to be safe.
Old May 20, 2007 | 07:44 PM
Default Re: (iowecharles200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iowecharles200 &raquo;</TD></TR><TR><TD CLASS="quote">it looks like build up to me.
wipe it off and look. might as well replace the pan gasket to be safe. </TD></TR></TABLE>
Old May 20, 2007 | 09:28 PM
stumpyf4's Avatar
Rear main seal looks good. Change out the oil pan gasket. Make sure everything is dry (oil free) when you install and you don't overtighten it.
Old May 20, 2007 | 09:43 PM
Dartanian's Avatar
Since you have everything apart, you might as well replace it. At least I would.
Old May 20, 2007 | 09:58 PM
Default Re: (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">Since you have everything apart, you might as well replace it. At least I would.</TD></TR></TABLE>
dth0ng69
Sep 22, 2009 11:36 PM
Jose-aka-Pedro
Mar 4, 2007 06:28 PM
overdose
Apr 27, 2003 02:03 PM
