Greddy turbo timer on 2000 si.. HELP
New User
i have a 2000 si with greddy turbo kit,
i took my car to my shop which is awesome and theyy tried to hook up my greddy turbo timer and the thing wouldnt work, i think i have a factory alarm, the car came with it,, but it goes off of the factory unlock remote for my doors. well i decided to take a look at the wiring myself since i installed my own turbo i figured i could figure out why the TT wasnt working, i look at the wirirng and they had 2 wires that werent where they were supposed to be, according to the instructions greddy gave, my car has 2 ignition on wires , the way my shop installed the TT my car would shut off (motor) but all the electrical **** would stay on, but now that i rewired it according to Greddy none of it stays on, they installed one of the TT wires to the acc wire, according to the diagrahm no wire goes there, im supposed to connect the blue and green wires from the TT to each one fo the ignition on wires which i did, i know which wires they are cause i have a helms manual and it tells me clear as day which wires they are, i have no idea what the hell is wrong!!! i have done searches all over and find nothing! if you can help me i would appreciate it!!!! my aol aim is: TeamRedlineNYC if you have aim you can contact me there if not please email me back bro
thanx for your time
Eddie
thanx for your time
Eddie
easiest way is to take off your steering wheel cover that covers the ignition, follow those wires back to the fuse panel and strip them to wire the tt to the wires
still dont have it? my blitz looked hard but was easy. you say you acc does not stay on? some of mine works. when i take the key out everthing stays on but the ac. if you engine stays on but the acc, dont worry about it. do like the other guy said and trace the wires back from the colum. if you have to use a meter reader. will help alot. i double and tripple checked mine to make sure i did not screw up, with it and it helped me find all the wires i needed. hope this helped
