what ecu should i have?
Old May 20, 2007 | 04:13 PM
pompom's Avatar
Default what ecu should i have?
i bought a b16a swapped ef hatch and have no idea what ecu is in it, but it runs like a wet dog now. how can i check what i have and what would you guys recommend i use?
Old May 20, 2007 | 04:28 PM
CRX_1.8T's Avatar
Default Re: what ecu should i have? (pompom)
What OBD is your car right now?
http://www.hondata.com/techecuid.html
Old May 20, 2007 | 04:46 PM
jdmcars.com's Avatar
Assuming your car is still OBD0 -you would want to look for the tag on the ECU, and look for a PW0 or PR3 on that white tag.
If your car was converted from OBD0 -you would probably see a cluster of wires going into another cluster -a jumper harness. Then the ECU codes may be different
bara6075
Feb 19, 2008 04:22 PM
RACEPAK
Aug 2, 2006 09:16 AM
