HELP!!!!! Water in the engine... suggestons needed
Old May 20, 2007 | 12:42 PM
jdm_enthusiast's Avatar
Default HELP!!!!! Water in the engine... suggestons needed
alright so i was cleaning my engine bay yesterday and i got water in the spark plug chamber.... when i tried getting the water out it wasn't coming out so i pulled out the spark plug and the water went INTO the engine... and now the civic will start up but not all of the chambers are firing.... YOUR SUGGESTIONS AND HELP WILL BE GREATLY APPRECIATED!!!!
Old May 20, 2007 | 12:57 PM
t0p_sh0tta's Avatar
Default Re: HELP!!!!! Water in the engine... suggestons needed (jdm_enthusiast)
Change the spark plug and make sure that the spark plug boot/wire isn't wet and try again.
Old May 20, 2007 | 01:06 PM
Crispy's Avatar
Default Re: HELP!!!!! Water in the engine... suggestons needed (t0p_sh0tta)
x2
you should be fine, I'm assuming it was a small amount of water?
Old May 21, 2007 | 08:53 AM
PhantomLord's Avatar
Default Re: HELP!!!!! Water in the engine... suggestons needed (Crispy)
Find out wich cylinders are not fireing, then remove the plug and disconect the fual injector on that cylinder. Now start up the motor and let the water work its way out. We did this after my friend put his lude through a huge puddle and sucked a bunch of water into his engine.
Old May 21, 2007 | 02:51 PM
Crispy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomLord &raquo;</TD></TR><TR><TD CLASS="quote">Find out wich cylinders are not fireing, then remove the plug and disconect the fual injector on that cylinder. Now start up the motor and let the water work its way out. We did this after my friend put his lude through a huge puddle and sucked a bunch of water into his engine. </TD></TR></TABLE>
He already ran the engine unfortunatly.
I asked how much water got in to see if other damage could have been done
Old May 21, 2007 | 05:37 PM
silk106's Avatar
You should be fine. As long as you only started it up and didnt really drive it and rev it up to much. Just pop out the spark plugs and and if you want the injectors and crank it over a few times and watch the water blow out. Or use a vacumn tube and suck the water out.
Old May 25, 2007 | 09:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy &raquo;</TD></TR><TR><TD CLASS="quote">
I asked how much water got in to see if other damage could have been done</TD></TR></TABLE>
I know he ran the engine, but it sounds like he ran it with the plugs still in. If he takes the plug out of the cylinder that has the water in it and then runs it, the water will spray out through the plug hole. Thats what I was trying to say. Sorry for the confusion.
Zaakro
Feb 1, 2007 11:29 AM
rrmorseb18c
Apr 9, 2006 08:20 AM
hatchback_al
15
Jul 21, 2004 02:15 AM
RH-TEG
Jun 25, 2003 07:08 PM
