how to change struts on 92 accord
Old May 20, 2007 | 12:30 PM
hondaguy3700's Avatar
Default how to change struts on 92 accord
does any one have a diagram that shows how to changes struts.
Old May 20, 2007 | 12:34 PM
hondadude's Avatar
Default Re: how to change struts on 92 accord (hondaguy3700)
3 nuts on top 2 bolts at the bottom
strut spring compressor tool
Put it back the way it came apart, the springs seat into little spots of the bases.
Mark it before taking it off
Old May 20, 2007 | 06:45 PM
soon2bdropped's Avatar
theres a diy on http://www.cb7tuner.com
its pretty easy.. i've lowered about 10 cars already..
Old May 21, 2007 | 08:38 AM
accordingtoh22's Avatar
Default Re: how to change struts on 92 accord (soon2bdropped)
not to be condescending, but if you can't figure it out, i wouldn't recommend doing it.
it's pretty simple, just pull the 3 bolts at the top (NOT THE ONE IN THE MIDDLE YET), the 2 on the bottom, where it connects to the knuckle, pull the brake line off, and pull the strut out. then you need to compress the coil spring, and take off the center nut on top.
best way to take that nut off is with an impact if you're not reusing the strut. if you are re-using the strut, then you need to either get the special tool, or find a combination of a box end wrench, and allen key to do it. if you spin the shaft inside the strut, you will rip the seals. alot of people will tell you to use an impact on and off, but i don't recommend it.
reverse that order to put everything back together.
and yes i'm sure there's a DIY with pictures on CB7Tuner.
Old May 22, 2007 | 01:32 PM
Bruce Banner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soon2bdropped &raquo;</TD></TR><TR><TD CLASS="quote">theres a diy on http://www.cb7tuner.com
its pretty easy.. i've lowered about 10 cars already..</TD></TR></TABLE>
I thought we weren;t allowed to link sites like cb7tuner here.
Old May 22, 2007 | 03:31 PM
90exaccord's Avatar
Default Re: how to change struts on 92 accord (Bruce Banner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Banner &raquo;</TD></TR><TR><TD CLASS="quote">
I thought we weren;t allowed to link sites like cb7tuner here.</TD></TR></TABLE>
in cb7tuner we link HT sometimes, i dont see nothing wrong with that IMO
Old May 22, 2007 | 04:13 PM
gosu08's Avatar
Default Re: how to change struts on 92 accord (90exaccord)
here is a step by step DIY.
http://www.cb7tuner.com/vbb/showthread.php?t=179
Old May 22, 2007 | 04:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90exaccord &raquo;</TD></TR><TR><TD CLASS="quote">
in cb7tuner we link HT sometimes, i dont see nothing wrong with that IMO </TD></TR></TABLE>
I think the mods do. lol
Old May 24, 2007 | 04:18 PM
flight50's Avatar
i cross link when ever i need to help someone find the answer. all forums i have been on cross link as well. as far as your struts, are you replacing with stock or aftermarket with lowering springs. there's a difference. the springs will need to be compressed properly depending on the situation. improperly compressing them can result in great harm to yourself.
ZombiePharoh
Mar 6, 2012 07:29 PM
navcc
Apr 8, 2011 03:10 PM
spooky187
Acura TL, RL & ZDX
13
Jun 27, 2010 04:58 PM
four o two
Jan 6, 2006 05:55 PM
jagged4698
Mar 5, 2004 08:33 PM
