What do i have to pull out to change body harness?
I just got an ex body wire harness and was wondering what i would have to pull out to put it in. Is it just the Dash or do i have to pull Everything out?
- Description from seller - "The harness plugs into the engine harness, goes through the firewall on the drivers side, into the fuse box and the rest of the cars wiring including the doors. It then travels under the dash to the passenger side and back out into the engine bay to plug back into the engine harness."
Just pull out the dash?
Or pull everything out?
anybody???
my car is a vx with d15b motor with 5-wire o2 and im planning on swapping a si d16z6 motor. since im swaping the motor i also picked up an ex body harness so it could be plug and play. My friends told me that the vx harness should also be plug and play but i dont think so since the harness is for a 5-wire o2, they also told me my vx harness has connectors for power window but i dont see them. The ex harness im picking up is for the d16z6 motor and it also comes with connectors for pwoer windows.
Anyone ever take apart the dash? i need to know if the body harness is in front of the vent tupes and blower motor or is the harness behind it towards the firewall.
There is a harness that runs across the fire wall. Also down the drivers side frame rail and to the back of the car. I pulled the carpet and all when I didd my rewire.
the main cabin harness runs under the carpet. it un clips near the cabin fuse box and runs through the firewarr on the passergers side. it then un clips fron the under-hood fuse box, engine harness and then runs to the headlight.
Landman93
Feb 1, 2016 01:30 PM
coupedragracing
Aug 7, 2011 06:36 PM
V/\ freestyle
Mar 13, 2011 08:52 PM
