my '88 crx si build
Old May 20, 2007 | 07:43 AM
aimmotorsports's Avatar
Default my '88 crx si build
trying to figue out how to post pics on here...
pics at http://xceedspeed.com/forums/showthread.php?t=68018
compleate restoration, build up of a sigle cam drag car. im useing the stock d16a6, custom cam, ported head with three angle valve job, vitaras, eagle rods, lightend cank, acl bearings and more. will also end up with eaither a t3/t4 60 trim, or a gt32r turbo. im looking at makeing somewhere around 350-400 hp at the wheels. 10pt roll cage, 22x9x13 slicks, 1 gal fuel cell, odyssey 680 battery, fiberglass dash, poly seat, aluminum rear lca's, kyb agx's, ground control copy coil overs (got them with the car, will be switching to skunk drag coils), custom fab'ed traction bar, poly bushings (i cant find solid), removed undercoating and sound deading, custom smoth firewall, msd, obd1 conversion, tuned on crome useing a po6 and much more...
i will get pics here as soon as i can figure out how...
Old May 21, 2007 | 09:14 AM
anyone care to explain how to post pics?
Old May 21, 2007 | 09:19 AM
Bob_760's Avatar
Default Re: (aimmotorsports)
You need to use the URL to a specific image i.e. http://images.honda-tech.com/new/1/img.gif then you put [ IMG] and [/IMG] (without the space) on either side of it or click on the insert image button and put in the URL then say OK
Also for posting links (like you tried to do) just put the URL in and it'll automatically make it a hyperlink.
Old May 21, 2007 | 07:23 PM
Default Re: (Bob_760)
thanks i will get some pics up inthe next day or so...
got alot done today. removed all glass, tail lights, rear bumper, shifter, compleat front suspension, seats, stering collum, rear reinforcemnt bar, doors, and hatch. also started striping the paint and seam sealer.
Old Jun 4, 2007 | 05:22 PM
recived the tube for the rear axle today and welded up the motor mounts so they arent just spot welded in. firewall is all welded and ready for the bondo.
jsw_1986
Welding / Fabrication
Jun 5, 2011 02:21 PM
BellDevelopment
38
Jan 25, 2011 10:21 PM
AutoLab
Aug 15, 2005 04:48 PM
mycivicduty
Mar 5, 2003 06:46 PM
