Looking for input on trans noise and 2nd gear popping out
Old May 20, 2007 | 05:33 AM
JokerX-1.6T's Avatar
Default Looking for input on trans noise and 2nd gear popping out
I just did the auto to manual swap on my 00 civic ex and put in a 96 hydro manual trans with new exedy stage1 clutch , act streelite flywheel , TOB and pilot bearing and filled with honda mtf. Ths trans is making a grinding noise at idle and speeds up when you give it gas while in gear but goes away when you engage the clutch and comes right back when you disengage it. All gears hold fine except for 2nd gear which will pop right back out as soon as you let the clutch out and grinds like crazy. I have read so many pages on this here Im not sure what to try besides replacing the trans .
Any input in this would be great as the car is running fine and rest of the swap related stuff went perfect no codes or anything
Old May 20, 2007 | 07:55 AM
IN VTEC's Avatar
Default Re: Looking for input on trans noise and 2nd gear popping out (JokerX-1.6T)
You got one or more bad bearings inside the transmission and the 1st-2nd synchro set and 2nd gear should be replaced.
It'll probably cost about $400 to $500 worth of parts.
Old May 20, 2007 | 07:48 PM
sounds like I bought a real winner
twkdCD595
Apr 15, 2022 05:28 PM
Axatax
Transmission & Drivetrain
Jan 4, 2013 05:06 PM
!moops vs moors!
Apr 13, 2007 08:47 PM
Qwikrex
23
Apr 22, 2003 11:07 AM
