F20C exhasut ports vs. K series?
Old May 20, 2007 | 04:02 AM
psegs80's Avatar
Default F20C exhasut ports vs. K series?
I'm buying a EG6 race car with a f20c (S2000) motor that was converted to front wheel drive with a RSX-S trany...I'm not buying the engine but I will drop in a K20a!
The owner had a set of custom header done, will they work with a K20a?
The wirring harness was from an S2000, will it work with a k20a?
The ecu is a AEM for a f20c, will it work for a k20a/
Thanks!!!
Old May 20, 2007 | 05:09 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: F20C exhasut ports vs. K series? (psegs80)
pics ?.. i've never seen a f20c in a fwd platform.. thats just crazy.. you sure ?
Old May 20, 2007 | 05:33 AM
gibsanez's Avatar
I'd like to see how he did an F2K .
The header will not work.
Old May 20, 2007 | 11:21 AM
ipodhustle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">I'm buying a EG6 race car with a f20c (S2000) motor that was converted to front wheel drive with a RSX-S trany...I'm not buying the engine but I will drop in a K20a!
only one way to find out. if not there are plenty of k swap headers available.
probably not. there are plenty of k swap harnesses available though.
shouldn't. there's an aem for k swapped vehicles though, or hondata k-pro.
Thanks!!!</TD></TR></TABLE>
Old May 20, 2007 | 01:19 PM
D-Rob's Avatar
Default Re: F20C exhasut ports vs. K series? (ipodhustle)
I saw pictures of this car a while back...
I think there was a bunch of pictures floating around H-T about this time last year.
- Derek
EDIT:
Here you go.
Modified by D-Rob at 5:56 PM 5/20/2007
Old May 20, 2007 | 06:42 PM
psegs80's Avatar
Default Re: F20C exhasut ports vs. K series? (D-Rob)
It's a eg6 that raced in the Canadian Hankook and was preped for the Castrol Canadian Touring Car Championship. it has TWM ITB...I will try to get pics for you guys! The owner made 211whp on a mustang dyno stock internals!
He used K series mounts
I have always been a big b18c type R fan and have own 3 on them...this will be my first K. I will get the ATS 5.06:1 FD and the 1.5way diff but will keep the engine internally stock for now (Budget reason)
is it better to leave a JDm k20a stock or buy a k20a2 and put the extra 2,000 in it?
Thanks
Old May 20, 2007 | 06:47 PM
The Destroyer's Avatar
Heh, just make a side exit with the RWD headers avail.
Old May 20, 2007 | 06:50 PM
psegs80's Avatar
Default Re: F20C exhasut ports vs. K series? (The Destroyer)
The regulation where I plan to race the car specify that exhaust exit need to be after the rear lower control arms
Pat
Old May 20, 2007 | 06:51 PM
Im sure there is a fabber somewhere close to you that would help out.
Old May 20, 2007 | 06:56 PM
psegs80's Avatar
Yes I know a few!!!
I was mostly wondering if the ones the owner had bolted up the a k!!!
Pat
Old May 21, 2007 | 09:18 PM
black cx's Avatar
wow
Old May 22, 2007 | 05:29 AM
6SPD_EK's Avatar
The owner had a set of custom header done, will they work with a K20a? most likely NO - maybe with extensive modification
The wirring harness was from an S2000, will it work with a k20a? NO - they are completely different... not too mention K-series has vtc
The ecu is a AEM for a f20c, will it work for a k20a - NO totally different
mounts are totally different as well
Old May 22, 2007 | 08:21 AM
psegs80's Avatar
Default Re: F20C exhasut ports vs. K series? (6SPD_EK)
Yes I went over and took a closer look..they where K-series mounts to strat with but underwent some customizing to take the f20c motor.
So all I will be keep from the seller is the sift linkage and header (will need so work to fit k)
Pat
Old Jun 8, 2007 | 08:05 AM
u5bebe's Avatar
what happened to the F20C? it's for sale?... thanks
Old Jun 9, 2007 | 09:57 PM
signalpuke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">Yes I went over and took a closer look..they where K-series mounts to strat with but underwent some customizing to take the f20c motor.
Pat</TD></TR></TABLE>
What shift linkage/shifter box is it using?
Forget the header, buy one made for the K motor.
Old Jun 10, 2007 | 04:31 AM
Black R's Avatar
25 Year Member
.....just use the f20c and save yourself a lot of headaches.
Old Jun 10, 2007 | 06:09 AM
JDogg's Avatar
Default Re: (Black R)
you can make the f20c wiring harness work, you may have to move some wires and then add the wires for the vtc to the ems, but that ems will control the k no problem.
kineticgsr
Honda S2000
Dec 4, 2009 10:54 AM
VtecKiDD
Performance
15
Oct 13, 2009 09:24 AM
Zero4488
Jun 26, 2005 09:46 PM
tampaSi
May 11, 2005 02:54 PM
KS-R
Aug 27, 2004 08:46 PM
