jdm b16 block with gsr head
Old May 19, 2007 | 09:17 PM
ctr status's Avatar
Default jdm b16 block with gsr head
So I want to do a high compression all motor build. Tell me what you think about this setup.
jdm b16a block
ctr pistons
jdm gsr head
port and polish, 3 angle valve job
toda b cams and cam gears
valves, valve springs, and retainers
Blox IM
ITR tranny
exedy organic clutch and flywheel
This will be going in my ek hatch. Should I get a new throttle body? And what kind of injectors and engine management would you suggest?
Also, if I was to just start out with the b16 block with ctr pistons and stock gsr head, would it be quicker than a straight stock gsr motor?
Old May 20, 2007 | 09:08 AM
moehp's Avatar
Default Re: jdm b16 block with gsr head (ctr status)
should pass 12:1 with that setup. The chamber is a bit smaller in the gsr head.
Old May 20, 2007 | 09:45 AM
kartman5's Avatar
Default Re: jdm b16 block with gsr head (moehp)
My son has the same set-up but went with a port and polished b16 head with
BC 4 cams. His set-up works great and he used the Hondata S-200 system.
Good luck its's a great set-up.
Old May 20, 2007 | 10:41 AM
ctr status's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moehp &raquo;</TD></TR><TR><TD CLASS="quote">should pass 12:1 with that setup. The chamber is a bit smaller in the gsr head.</TD></TR></TABLE>
Yeah, I used this compression calculator http://www.zealautowerks.com/ , and it says that my compression should be 12.25, this will be safe to run pump gas right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kartman5 &raquo;</TD></TR><TR><TD CLASS="quote">My son has the same set-up but went with a port and polished b16 head with
Good luck its's a great set-up.</TD></TR></TABLE>
I was thinking about hondata myself, I was also thinking about getting an afc, but im not sure how helpful it would be.
Old May 20, 2007 | 10:58 AM
RC_Rikimaru's Avatar
sounds like its goin to be juicy. good setup.
Old May 20, 2007 | 02:08 PM
doood's Avatar
been there done that
you would not need an afc with hondata
Old May 20, 2007 | 04:29 PM
ctr status's Avatar
Default Re: jdm b16 block with gsr head (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">you would not need an afc with hondata</TD></TR></TABLE>
I meant just running an afc without hondata, but i dunno if that would be good enough
Old May 20, 2007 | 04:30 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr status &raquo;</TD></TR><TR><TD CLASS="quote">
I meant just running an afc without hondata, but i dunno if that would be good enough</TD></TR></TABLE>
it wont
Old May 20, 2007 | 04:52 PM
allnaturalb16's Avatar
good fun setup!! i run wiseco 11:1 pistons with a 97 gsr head and ITR cams. with the gsr head you will want a different manifold and i run a 68mm TB but the throttle body is too big i think 62-65 would be good with your cams.
310 cc injectors with hondata
Old May 20, 2007 | 05:36 PM
ctr status's Avatar
Default Re: jdm b16 block with gsr head (allnaturalb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">good fun setup!! i run wiseco 11:1 pistons with a 97 gsr head and ITR cams. with the gsr head you will want a different manifold and i run a 68mm TB but the throttle body is too big i think 62-65 would be good with your cams.
310 cc injectors with hondata </TD></TR></TABLE>
what IM and TB are you using?
Old May 21, 2007 | 07:21 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
i would do all this but with a 1.8 block ! but if u want 1.6 ok ur call.. but dont use blox at least use skunk 2 IM ! Ull gain couple more hp with the skunk IM
Old May 21, 2007 | 12:42 PM
Default Re: (RED_90TEG)
what IM and TB are you using?</TD></TR></TABLE>
i am runnning the AEBS manifold and a S2 replica 68mm TB
streetsold6teeny8
19
Jan 24, 2010 05:38 AM
Herzeleid
13
Mar 21, 2007 10:33 AM
chinpak
Mar 15, 2007 06:20 PM
jdmteg93
Oct 19, 2006 08:13 AM
blub18
Oct 4, 2006 07:51 AM
