strange problem
Old May 19, 2007 | 06:45 PM
95lscivic's Avatar
Default strange problem
about five minutes ago i was on my way home from work and i took a corner, right after the corner the stupid beeping noise from the rear view mirror started going off. my question is why? i don't have any of my seat belt sensors connected so it only beeps when the door opens, now it beeps all the time when the keys are on. myu question is that what could ber the problem? any help would be of great service. thanks agian.
Old May 19, 2007 | 07:57 PM
95lscivic's Avatar
Default Re: strange problem (95lscivic)
any help?
Old May 19, 2007 | 08:04 PM
Humayrayakongkinaon's Avatar
Disconnect it. Thats what i did to mine
Old May 19, 2007 | 08:07 PM
95lscivic's Avatar
Default Re: strange problem (Humayrayakongkinaon)
what did it disconnect?
*edit* i don't want to fix it that way, as it is not really fixed. i want to solve the problem. what could be causing the beeping to stay on, especially after months of working correctly.
Old May 19, 2007 | 08:10 PM
Theres I believe a green plug inside the housing of that rear view mirror
Old May 19, 2007 | 08:14 PM
EF_LSVtec's Avatar
check your door sensors (by the latch) maybe they're loose that's why you hear that beep when you make a sharp turn. That happened to me too, not the beep but the door light would come on when I make a sharp turn...
I taped a piece of cardboard on he door latch that triggers the sensor...solved the problem.
Old May 19, 2007 | 08:15 PM
95lscivic's Avatar
i know i put the mirror on lol i know how it works i just don't know why it's making the beep noise now. it has never done that before, only when the doors open. the light doesn't flash on the dash as if a seat belt is off either, it only makes the noise on rear view mirror.
Old May 19, 2007 | 08:23 PM
hon da top's Avatar
Edited by CRX Toad
Old May 19, 2007 | 08:25 PM
God-Driven's Avatar
my ef did the same thing the first week when I got it but I didnt do it anymore, Honda should make a TSB for this, lol yea right 16 years later.
Old May 19, 2007 | 08:26 PM
95lscivic's Avatar
Default Re: strange problem (hon da top)
wtf?
Old May 19, 2007 | 08:27 PM
95lscivic's Avatar
Default Re: (God-Driven)
did it eventually stop doing it? if it's a sensor bad how can i figure out which sensor it is?
Old May 19, 2007 | 08:28 PM
hon da top's Avatar
Default Re: (95lscivic)
Edited by CRX Toad
Old May 20, 2007 | 08:12 AM
95lscivic's Avatar
Default Re: (hon da top)
can i get some real help please? no more pointless and retarded pictures from hon da top.
Old May 20, 2007 | 09:04 AM
low91rex's Avatar
bump for you because that sounds annoying as hell
Old May 20, 2007 | 09:36 AM
jdmd15bciviconrice's Avatar
The same thing happened to my friends civic when he disconnected his seat belt sensors because his belts dont work the only thing that I know of you can do is to hook them back up or take the beeper out and thats what we did or you can run a wire to the sensor to make it seem like the seatbelt is working my-self and my friend are still trying to figure out how to do that so....iam pretty sure that its your seatbelt sensor.
Old May 20, 2007 | 03:52 PM
95lscivic's Avatar
Default Re: strange problem (jdmd15bciviconrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmd15bciviconrice &raquo;</TD></TR><TR><TD CLASS="quote">The same thing happened to my friends civic when he disconnected his seat belt sensors because his belts dont work the only thing that I know of you can do is to hook them back up or take the beeper out and thats what we did or you can run a wire to the sensor to make it seem like the seatbelt is working my-self and my friend are still trying to figure out how to do that so....iam pretty sure that its your seatbelt sensor.</TD></TR></TABLE>
i don't know man, this never happened before! i took a corner on my way home last night and it started beeping. i turned my car off opened and closed the doors again and it did it again. i don't know what the deal is.
Old May 21, 2007 | 12:40 AM
95lscivic's Avatar
ahh i figured it out! it was a ground that came lose next to the passenger headlight. thanks for the help.
Old May 21, 2007 | 05:33 AM
Colonel Warden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lscivic &raquo;</TD></TR><TR><TD CLASS="quote">ahh i figured it out! it was a ground that came lose next to the passenger headlight. thanks for the help.</TD></TR></TABLE>
Go through your vital wiring systems... if one wire could shake loose, then I'm willing to bet several could.
Wiretaju
Jun 24, 2010 08:31 PM
boostmee
Oct 22, 2007 05:57 AM
zach1288
Feb 6, 2007 08:34 AM
green91
May 18, 2005 05:13 PM
2000Accord5sp
Jan 21, 2003 12:20 PM
