how hot do headers get?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cars101 »</TD></TR><TR><TD CLASS="quote">i think somewhere around 250 degrees if not hotter</TD></TR></TABLE>
250 degrees?
Is that why the 500 degree Duplicolor engine paint I put on one burnt off within 4 minutes of running?
Is that why exhaust manifold paint is rated up to 1200+ degrees?
250 degrees?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">thats what i thought... so how much does manifold paint cost?</TD></TR></TABLE>
Usually about $8 or so. VHT Flameproof and Plasticote Manfiold Paint are some good brands. Make sure you have some time to drive around or watch your car for a while. To make the stuff stick, you've got to basically bake it on.
If you don't have an oven large enough for a header that goes up to 650 degrees (ie, a commercial oven or powdercoating oven) ... the easiest way is to install it on your car once it's dry enough, and then run it at idle for about two hours.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
1200+ degrees?</TD></TR></TABLE>
Turbo manifolds get hot enough to turn literally red hot. Headers get very hot as well.
well it's not registered or inspeced so i can't drive it but i do need to change the oil and run some injector cleaner through it so i guess i can bake it on after college tomorrow... do stores like autozone and o'reilly sell his paint?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">well it's not registered or inspeced so i can't drive it but i do need to change the oil and run some injector cleaner through it so i guess i can bake it on after college tomorrow... do stores like autozone and o'reilly sell his paint?</TD></TR></TABLE>
Most Autozone's will carry at least black and red VHT Flameproof.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">ya... i got a few areas of skin on the back of my hand missing from this bitch</TD></TR></TABLE>
It upsets me that you hail from the town in which I grew up. I hope I don't know you
georgiajdm
Apr 9, 2007 06:57 AM
bryphotoguy
Jun 19, 2006 04:13 PM
