Crank removal with block in car..
Old May 19, 2007 | 04:20 PM
eleet's Avatar
Default Crank removal with block in car..
Im doing a block notching for rod clearance.. I wanted to see how hard removing the crank would be?? What more would I have to remove? The pistons are out of the block.. Picture that.. d16y8
Old May 19, 2007 | 04:38 PM
DonF's Avatar
Default Re: Crank removal with block in car.. (eleet)
Why? Even if you can do that how are you going to clean the block and measure if you got it correct?
Old May 19, 2007 | 05:52 PM
Jago's Avatar
Default Re: Crank removal with block in car.. (DonF)
it would be easier to pull it because you would have to pull the trans, oil pump and everthing it takes to get all of that off
crazyjetsfan22
Northeast (Sales)
31
Feb 20, 2011 03:00 PM
efsihatch91
May 4, 2009 11:17 AM
civic_mattattack519
Sep 10, 2006 03:35 PM
whytTypeR
Feb 8, 2005 06:42 PM
