Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Installed aftermaket mirrors with blinkers, have question
Old May 19, 2007 | 04:08 PM
Untouchablex's Avatar
Default Installed aftermaket mirrors with blinkers, have question
I put a set of aftermarket side mirrors on my car, they didnt come with any instructions on wiring. I was able to figure out how to make them work with my switch properly, but im havin a problem hookin up the blinker part. I ran the wires to the front blinker and it works fine until i turn on my headlights, then they donot work. Anyone kno whats wrong?
Old May 19, 2007 | 04:12 PM
al4t1gbundy's Avatar
whats wrong is you putting those mirrors w/ blinkers in teh first place
Old May 19, 2007 | 04:13 PM
Type X's Avatar
Default Re: Installed aftermaket mirrors with blinkers, have question (Untouchablex)
possibly blew a fuse?
Old May 19, 2007 | 04:17 PM
sickyute's Avatar
Default Re: Installed aftermaket mirrors with blinkers, have question (Type X)
wire them to the fuse box ... not the turn signal itself ...
Old May 19, 2007 | 04:40 PM
Im not sure on how to wire them to the fuse box. They look great and work fine. They just dont work when the lights are on.
Old May 19, 2007 | 05:08 PM
MessGSR's Avatar
Default Re: (Untouchablex)
what u have to do is remove the Ricewall.........but then that leaves ur car unprotected from Rice
Old May 19, 2007 | 05:21 PM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Untouchablex &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure on how to wire them to the fuse box. They look great and work fine. They just dont work when the lights are on. </TD></TR></TABLE>
alot of the wiring on the civic is REVERSED.
hard to explain.
But check your grounds, might even need a relay
Type X's Avatar
Default Re: (MessGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MessGSR &raquo;</TD></TR><TR><TD CLASS="quote">what u have to do is remove the Ricewall.........but then that leaves ur car unprotected from Rice </TD></TR></TABLE>
Please keep the retarded comments to umm Zero.
Old May 19, 2007 | 05:24 PM
MessGSR's Avatar
Default Re: (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">
Please keep the retarded comments to umm Zero.</TD></TR></TABLE>
nothing wrong with poking a lil fun every now and then
Old May 19, 2007 | 05:36 PM
Type X's Avatar
nothing wrong with poking a lil fun every now and then</TD></TR></TABLE>
Especially when someones new cars wiring is concerned right?
Old May 19, 2007 | 05:52 PM
there are 3 wires goin into the blinker on the car i think that might have something to do with it. Theres only 2 wires from the blinker on the mirrors
Old May 19, 2007 | 05:59 PM
Type X's Avatar
power trigger & ground?
i'm going out boozing i'll bbl to check this.
Old May 29, 2007 | 07:04 AM
sickyute's Avatar
no sure if u still need help ... but ...
under the steering wheel u'll see the fuse box and plugs ... there's a long green plug (think it's a 42 pin) ...
using a tester ... turn ur indicators on and see which one blinks for left and which blinks for right ...
those wires will only control blinking so ur mirrors will only blink and not come on with the park lights ...
so u wire them in ... either tap or solder ...
find a good ground and u r done ...
the wires are easy to get to ...
u just have to go through the pain to running the wires through the door and through oem spots to get to the source.
Old May 29, 2007 | 08:38 AM
IT GUY's Avatar
Default Re: (sickyute)
I don't care what anyone says... I like the Civic Hybrid Mirrors with the Signals in 'em
datssoled
Jul 30, 2009 09:54 AM
prejdmlude
May 24, 2007 05:14 PM
jdm_bones
Jul 31, 2006 10:01 AM
EgGriff
May 22, 2006 04:48 PM
typer464
Dec 3, 2001 04:33 AM
