Pics of my DIY Turbo
d16z
arias pistons
ls rods
nuformz block guard
head work (all done by rps in torrance)
cx manifold-ported
adapter plate
14b
dsm 1g bov
starion intercooler
missing link
fmu
airnex inline
greddy profec a and turbo timer
silcone connectors from xs-engineering
charge pipes from JCwhitney
[Modified by turboorangecx, 5:09 AM 6/2/2002]
arias pistons
ls rods
nuformz block guard
cx manifold-ported
adapter plate
14b
dsm 1g bov
starion intercooler
missing link
fmu
airnex inline
im trying to do this for my little brothers car....what the info on a cx manifold? just slap the turbo on? is that what the adapter plate is for?
what turbo are u using?
how's the performance of the 14b? I got a T-25 for cheap ($85) but I was really lookig for a 14b or cheap 16g. Where from and how much did you get your starion i/c for?
How much did it cost to get the endtank pipes on the side instead of the top? Did you just get whole new endtanks or did you modify the stock ones?
The 14b pulls great
What did you do for the downpipe? Im currently building a kit and I was wondering how hard it was to make the downpipe, I've heard that it can be a pain. At first I wanted to use a t3 with a revhard/drag manifold so I can keep the a/c but I heard with that turbo the exaust downpipe configuration aims it toward the block or radiator. So now I'm thinking to just ditch my a/c and use the 14b/hf manifold setup, seems like it would be less of a headache this way. What(if any) difficulties did you have with building this kit and installing it?
Btw: can you list which pipes you ordered from jc whitney since I'll be ordering mine soon? I'd REALLY appreciate that
[Modified by AztecGreenEJ, 7:32 AM 6/3/2002]
awesome kit, the design of the the endtanks arent the best and would flow better if you mounted the new openings near the stock one... but other than that, awesome setup.
what did you do for the fittings on the coolant?? brass fittin right htere you have hooekd up, did you just pick that up from home depot? is that fornt part coolant in or coolant out ? or does it not matter, because im helpin a friend do a DIY turbo kit for his 89 civic hatch also and i'd like some input, thanks
Constructive critisism: those are TERRIBLE end tank designs to use for a side fed cooler... I know you simply cut off the original piping and relocated it.. but to be honest, the flow with the current setup is far from efficient.
as i remember, there is no modification needed for ls rods
it fits tight, i think
corret me if i amwrong
j/k i think though the rods DO need to be modded to fit. I think the wrist pins don't fit on the rods... some crap i forget now
