Will 215/45/16 rub on an EG?
Old May 19, 2007 | 10:27 AM
teejlc's Avatar
Default Will 215/45/16 rub on an EG?
Old May 19, 2007 | 07:35 PM
db8gsr_teg's Avatar
Default Re: Will 215/45/16 rub on an EG? (teejlc)
yes
Old May 19, 2007 | 07:43 PM
teejlc's Avatar
Default Re: Will 215/45/16 rub on an EG? (db8gsr_teg)
will rolling the fenders help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8gsr_teg &raquo;</TD></TR><TR><TD CLASS="quote">yes </TD></TR></TABLE>
Old May 19, 2007 | 08:24 PM
db8gsr_teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teejlc &raquo;</TD></TR><TR><TD CLASS="quote">will rolling the fenders help?
i dont know but i think you should go with 205-40-16
Old May 20, 2007 | 06:43 AM
DaveSi677's Avatar
i dont know but i think you should go with 205-40-16</TD></TR></TABLE>
Agree!
That size is to big for your car. You wont see any performance gains from having a wider tires! Don't be a fool and get the proper size for your car which is 205-40-16.
Old Aug 13, 2007 | 05:16 AM
jg's Avatar
jg
Default Re: Will 215/45/16 rub on an EG? (DaveSi677)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveSi677 &raquo;</TD></TR><TR><TD CLASS="quote">
...You wont see any performance gains from having a wider tires! ...</TD></TR></TABLE>
This is a very interesting statement.
Old Aug 13, 2007 | 09:25 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Will 215/45/16 rub on an EG? (jg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jg &raquo;</TD></TR><TR><TD CLASS="quote">This is a very interesting statement.</TD></TR></TABLE>
You won't see any huge performance gain. People sometimes think they are going to get tremendous grip by getting tires that are 10 mm wider, but you won't. I bet if you did a blind test (where someone changed the tires for you and you didn't already know which ones were on the car), you wouldn't be able to tell any difference based on driving the tires with different treadwidths in back-to-back sessions.
If you have a pre-'96 Civic, put 205/40-16 tires on it. If you are looking for the best performance, just put on the best 205/40-16 tires you can (i.e. Falken Azenis RT-615).
Old Aug 14, 2007 | 05:29 AM
jg's Avatar
jg
Default Re: Will 215/45/16 rub on an EG? (nsxtasy)
I still disagree. If you run a 205/40 against a 215/45 Falken 615 back to back on the street and on a track, I would put money the latter would perform noticeably better.
Don't forget about the increased sidewall you'll have from the 215/45 vs. the 205/40. The added height will help keep the teeth in your head, and your wheels true (I live in MI). Maybe i'm getting old...
Old Aug 14, 2007 | 05:32 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jg &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget about the increased sidewall you'll have from the 215/45 vs. the 205/40. The added height will help keep the teeth in your head, and your wheels true (I live in MI). </TD></TR></TABLE>
That's really BAD ADVICE. You're making one mistake (wheels too large for ride comfort), and then making a second mistake (the wrong size tires) instead of fixing the first one.
If ride comfort is a priority for you, then don't get 16" wheels, period. Get smaller wheels, and you can get the proper size tires - 15" wheels with 195/50-15, or 14" wheels with 185/60-14 - with higher sidewalls for greater ride comfort.
Old Aug 14, 2007 | 05:33 AM
jg's Avatar
jg
To each his own. Just speaking from experience.
Old Aug 14, 2007 | 06:02 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jg &raquo;</TD></TR><TR><TD CLASS="quote">Just speaking from experience.</TD></TR></TABLE>
So am I.
Old Aug 14, 2007 | 12:14 PM
BigChance's Avatar
what would happen when you turn?
Old Aug 14, 2007 | 07:46 PM
GReatEDDY's Avatar
Running 215-45-16 on 16x7's on a EM1 2.2"down. Camber and toe on the bottom end of oe specs. Fronts will pull the fender liner fastners and the fender tabs out, rears will scrap the paint on the rears. Roll the rears a little from the 10-2 oclock on the rear wells. ek same. EG do the 205-40-16 and take advantage of the lower gearing. No rub imo
Old Aug 15, 2007 | 07:35 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (GReatEDDY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReatEDDY &raquo;</TD></TR><TR><TD CLASS="quote">Running 215-45-16 on 16x7's on a EM1 2.2"down. Camber and toe on the bottom end of oe specs. Fronts will pull the fender liner fastners and the fender tabs out, rears will scrap the paint on the rears. Roll the rears a little from the 10-2 oclock on the rear wells. ek same. EG do the 205-40-16 and take advantage of the lower gearing. No rub imo</TD></TR></TABLE>
That's correct. The '97-00 Civic, including EM models, are designed to use larger tires, so they can use 205/45-16 or 215/45-16. Older Civics, including the '92-95 EG models, are designed to use smaller tires, so they need 205/40-16.
dc5*brian
Oct 2, 2007 12:35 PM
jerebear
Jan 10, 2007 06:40 PM
Declectic
Nov 17, 2005 05:29 PM
EssEg
Apr 27, 2005 04:47 PM
i hate my team
Apr 18, 2005 12:24 PM
