How important is it to run coolant lines to the turbo
Old May 19, 2007 | 09:19 AM
jfruauff's Avatar
Default How important is it to run coolant lines to the turbo
Ok heres the problem. I turbo has oil and coolant ports. Well the turbo sits so close to the block i cant get any hose on the coolant port. I am using a 90 elbow now ant it works but leaks because i have to have it face up and wouldnt get tight enough so it drips. I know the oil is 100 % needed for the bearings but always heard the coolant was just a bonus for the long term.
How many people run turbos that have coolant cooling option and dont use it.
Old May 19, 2007 | 09:54 AM
GiNuWiNe's Avatar
Default Re: How important is it to run coolant lines to the turbo (jfruauff)
Have you tried clocking the turbo? If your turbo is Ball-bearing i highly suggest you run those lines.
Old May 19, 2007 | 10:02 AM
jfruauff's Avatar
Default Re: How important is it to run coolant lines to the turbo (GiNuWiNe)
Hey i tried clocking it but it in a car with a/c and everything is tight. i dont think its ball bearing just had it rebuilt dont think its ball bearing.
Old May 19, 2007 | 03:20 PM
mrbsponge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfruauff &raquo;</TD></TR><TR><TD CLASS="quote">Hey i tried clocking it but it in a car with a/c and everything is tight. i dont think its ball bearing just had it rebuilt dont think its ball bearing.</TD></TR></TABLE>
it can be done, i had a 35R with AC in a 99si
you just have to clock the turbo on the manifold, it will take a bit but it will work, also make sure you are using the right thread fitting, my buddy had the wrong threaded fitting, it went in but wouldnt seal all the way
also check out http://www.atpturbo.com
they have about 4 different kits for water cooled turbos
95BoostedEJ1
Feb 22, 2009 08:15 AM
integraboosted
Apr 1, 2006 08:18 AM
11psiTurboSI
Dec 21, 2004 04:52 PM
You_Get_Vapors
May 4, 2003 06:17 PM
