Suspension Upgrades: Requesting Advice
Old May 19, 2007 | 07:33 AM
PB BB1's Avatar
Default Suspension Upgrades: Requesting Advice
First off I'm driving a 95 VTEC. It has been lowered with some type of red springs (thats the best I can tell you) on the stock struts which must be totally shot. That or I have bigger problems. I'm assuming when it feels like you are being dragged behind a car in a sheet while driving (what?) that you need new struts. There is a ton of skipping over the tiny bumps as well. The car bottoms out all of the time. I feel I have made the proper diagnosis, please correct me if I am overlooking anything.
So on to it... Seems everyone loves their tokico illuminas, and while they probably are a tad overkill for my needs its still the set I'm leaning towards most. As for springs, I'm leaning towards the RS-R as they offer performance without lowering the car quite as much as the competitors. This appeals to me, but I was unable to find a review in my searching, and the RS-R springs are the most expensive. The only thing I have to go on is that I'm thrilled with my RS-R exhaust, and am counting on the same quality.
In a nutshell I'm definitely going to go with the illuminas unless someone talks me out of it and I'm stumped on springs.
Please help me H-T.
Old May 19, 2007 | 09:58 AM
vinuneuro's Avatar
Default Re: Suspension Upgrades: Requesting Advice (PB BB1)
If you want height adjustability, get Ground Control coilovers. If that isn't so important, get Eibach Pro-kit or Sportline springs depending on how much you want to lower the car.
Old May 19, 2007 | 11:18 AM
PB BB1's Avatar
I do not require height adjustability... I'm thinking now perhaps I am not in need of the adjustable struts.
It looks as though I was mistaken: the RS-R set is not the most expensive. Eibach Pro-kit looks very nice, but the Sportline is out as I am not looking for that extreme of a drop.
Thanks for the input.
EDIT: Any other opinions on setup?
Old May 19, 2007 | 12:56 PM
typeS's Avatar
You may want to check into some KYB or Tokico struts, adjustable or not. Also, look at the Tein S tech springs. They will lower you a little bit, and give you a nice ride since they are progressive rate. You might also want to check your ball joints and strut mounts and what not while you're in there.
[CG]
Suspension & Brakes
13
Jul 30, 2009 10:39 AM
Armorzaku
Mar 16, 2009 07:19 PM
TwoKSiR
Nov 29, 2006 03:28 PM
DNBINSTINCT
Jan 6, 2006 10:28 PM
216.226.142.95:27016
May 1, 2003 08:22 AM
