setting timing on 88 crx si???
Old May 19, 2007 | 06:57 AM
classciv's Avatar
Default setting timing on 88 crx si???
ok, my car idols at 3k, i have instaled 3 tps sensors checked all wiring and it still does it. i am thinking it is out of time. i have never had to put an engine in time before so what are the steps for an 91 crx si engine
Old May 19, 2007 | 07:11 AM
dr_latino999's Avatar
Default Re: setting timing on 88 crx si??? (classciv)
Have you tried adjusting the Idle Adjustment Screw?
Old May 19, 2007 | 09:58 AM
classciv's Avatar
Default Re: setting timing on 88 crx si??? (dr_latino999)
yes i have
Old May 22, 2007 | 12:37 PM
classciv's Avatar
could a bad distributor be the problem?
Old May 22, 2007 | 12:44 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
check for a random vacuum leak
Old May 22, 2007 | 12:58 PM
classciv's Avatar
Default Re: setting timing on 88 crx si??? (Teddy Ruxpin)
i have gone over all the vacume lines, but i can check them again for damage, what are the chances that it is out of time or the distributor is bad though?
89CRXSIHutch
Jul 25, 2008 02:51 PM
red-noser
Sep 28, 2004 05:59 AM
blayzenazn
Mar 23, 2002 11:14 PM
Teluan
Aug 29, 2001 10:59 AM
