Honda S2000 Honda S2000
Test drove an S2K--diff between model years?
Old May 18, 2007 | 04:02 PM
Nolamike's Avatar
Default Test drove an S2K--diff between model years?
Just test drove an '07 s2k. i'm looking at buying an s2k (prob '04-05), vs. bmw z3/z4 vs. boxster. leaning towards the s2k because of reliability, insurance, and cost.
thoughts on the drive: i'm 6'2, 185# and fit in the car without a problem--didn't seem cramped. i was worried about this. there is really no storage space. it wasn't as fast as i thought it would be, but it also wasn't as noisy or rough-riding. i'm now looking at differences between model years. i've found conflicting info. a couple of questions:
looking at an ap2. any real differences from '04 onward? looks like the stereo changed, with headrest speakers coming in '05 (?), though it appears they're not that hard to add on to earlier years. is that true?
a few conflicting reports on when traction control became standard--not sure who to believe on that one.
the stereo appears to be a standard DIN fitting, which is refreshing. if i pop in an aftermarket headunit, what needs to be done to get the steering controls to work?
anything else i should know before buying?
Old May 18, 2007 | 04:40 PM
LAS2K's Avatar
Default Re: Test drove an S2K--diff between model years? (Nolamike)
check my sig.
Old May 19, 2007 | 05:29 AM
Nolamike's Avatar
thanks. looks like the traction control is only on 06+ models. too bad.
every other search i do ends up in an ap1 v. ap2 debate. is there a source that lays out all the changes from year to year?
Old May 19, 2007 | 03:48 PM
4doorH22's Avatar
Default Re: (Nolamike)
From http://www.hondanews.com/categ.../1501
The 2004 S2000 benefits from the following major enhancements:
Larger displacement 2.2-liter engine (240 horsepower @ 7800 rpm and 162 lb.-ft. of torque @ 6500 (replaces 240 hp @ 8300 rpm and 153 ft.-lbs. @ 7500 rpm )
Larger wheels and tires (17-inch)
Revised suspension tuning
Revised transmission gear ratios and improved shift feeling
Bolder front and rear exterior styling
Freshened interior design
New options including XM Satellite Radio™ and headrest speakers
2006 added the VSA stability control.
mr.elite
Oct 6, 2016 12:16 PM
toomspeed
Honda S2000
Jul 20, 2009 06:47 AM
imadigitalgod
Audio / Security / Video
17
Jan 5, 2007 11:47 AM
chris1866
Honda S2000
Jun 5, 2005 03:19 PM
