my car smells like gas....
Old May 18, 2007 | 12:41 PM
zhan28's Avatar
Default my car smells like gas....
my car smells like gasoline, wtf is wrong with it? when i get on it, something smells like gasoline, it sucks and gives me a headache, but it's pulling hard and made 180whp on this set up:
b20b block:
Eagle H-beam rods
Je 12.5 to 1 cpr pistons
b16a head
Skunk2 Stg 1 cams
Crower titanium retainers
Crower dual valvesprings
Type R intake manifold
dented DC sports Headers
Trust (old school Greddy) SP Exhaust
lmk if you can help!
Old May 18, 2007 | 01:43 PM
707CIVIC's Avatar
I THINK I HAD THE SAME PROBLEM, ITS SMELLS LIKE GAS I PERSONALLY THINK ITS UR TUNE. UNTILL I GOT A GOOD TUNE IT SMELLED BAD AND I THINK U SHOULD HAVE GOT MORE POWER THAN 180 CAUSE I GOT 188 ON A B18C WITH A BUILT HEAD AND CAMS WITH A STOCK BLOCK.
Old May 18, 2007 | 02:09 PM
zhan28's Avatar
caps button is not your friend :-) but neways thanks for the input, i'm not making the power because i'm maxing my fuel pump and i have a super dented pos dc header.
Old May 18, 2007 | 05:21 PM
707CIVIC's Avatar
Same with me too they said i was maxing out my injectors and fuel pump also see if ur fuel pressure is too high, cause mine was. I also have a dent in my dc but after i got mine retuned my car runs super good . Also another question what tuner u using and do u have a problem at idle
Old May 19, 2007 | 04:58 AM
b19coupe's Avatar
Default Re: my car smells like gas.... (zhan28)
Is your evaporative emissions system open to the atmosphere? Do you have a fuel leak?
Old May 19, 2007 | 01:14 PM
lude98SH's Avatar
Default Re: my car smells like gas.... (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Is your evaporative emissions system open to the atmosphere? Do you have a fuel leak?</TD></TR></TABLE>
Why does your evap being open to the atmosphere matter ? Or do you mean open as in water may get in ?
Old May 19, 2007 | 01:32 PM
b19coupe's Avatar
Default Re: my car smells like gas.... (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zhan28 &raquo;</TD></TR><TR><TD CLASS="quote">my car smells like gasoline,</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">Why does your evap being open to the atmosphere matter ? </TD></TR></TABLE>
If your evaporative emissions system is open to the atmosphere, raw fuel vapor can escape into the air. You would smell gas if this was the case.
Old May 19, 2007 | 02:18 PM
lude98SH's Avatar
ooo duhhh i should have thought of that. thanks
Old May 19, 2007 | 10:41 PM
zhan28's Avatar
Default Re: (707CIVIC)
yes i do have problems at idels, it goes really low....
Old May 20, 2007 | 12:29 PM
Boostedb20EH2's Avatar
Default Re: (zhan28)
Just a suggestion, are your valves adjusted to spec?
civics4lyfe
16
Jan 29, 2016 07:19 AM
zhan28
11
May 17, 2007 12:55 PM
eg:R
Jan 18, 2007 10:53 AM
goldbrick
Jun 27, 2003 01:40 PM
