Tips for removing my exhaust silencer...
Old May 18, 2007 | 10:39 AM
g2tegsown's Avatar
Default Tips for removing my exhaust silencer...
Anyone have any tips for removing my exhaust silencer? It seems to be jammed in there pretty tight, I don't think it's going to ever come out lol.
Thanks
Old May 18, 2007 | 10:45 AM
EL Vap133's Avatar
Default Re: Tips for removing my exhaust silencer... (g2tegsown)
vice grips?
Old May 18, 2007 | 10:51 AM
g2tegsown's Avatar
Dude vice grips are not even budging this thing...
Old May 18, 2007 | 11:03 AM
CRX Toad's Avatar
Default Re: (g2tegsown)
Dremel, Plasma Cutter, Tin snips, Sawzall?
Old May 18, 2007 | 11:06 AM
DustinM's Avatar
Default Re: (CRX Toad)
did you remove the set screw?
Old May 18, 2007 | 11:07 AM
Janos Lin's Avatar
Default Re: (DustinM)
^^ would be my guess also. U sure it's removeable?
Janos
Old May 18, 2007 | 12:46 PM
RSZero1's Avatar
Default Re: (Janos Lin)
Use something with an expandable hook end. Insert into silencer expand hooks and pull like a ****.
Slide hammer would work too if you have something to hook into the silencer.
And when i say insert into silencer, i mean right down the center where it goes into the muffler, you want to pull from as close to center as possible.
Old May 18, 2007 | 03:38 PM
g2tegsown's Avatar
Know there is no place screw, its so tight I never put one in. And I tried pulling it out with vice grips and that thing is set in stone. "Use something with an expandable hook end" I was thinking that, but i can't think of a tool to do it. Should I spray like WD-40 is very sparse amounts around the ring just to get it moving, or would that be a bad idea because of the temp it reaches
Old May 18, 2007 | 03:49 PM
xfletcherxx's Avatar
Are you SURE its removable? O.o
And I don't see why WD-40 would make a difference because of temp. *shrugs*
Do it.
Old May 18, 2007 | 04:01 PM
g2tegsown's Avatar
Yeah I am sure it's removable, I put it in, it has "2 levels" and I had it in the first level and it was sticking out like a ****, so I put it in the 2nd level and now it's loud, so I am going to remove it, cut it, and then hopefully for now it will hide that super rice sound until I get my RS*R :D
Old May 18, 2007 | 04:07 PM
tougetuned_ef's Avatar
use brake cleaner. ots for brake disks you can spray as much as u want it evaporates on its own. also go to the hardware store and ask them for a big toggle bolt. it colapses so you can put it in and when its althe way through it snaps open and then you just pull the hell out of it.
Old May 18, 2007 | 05:26 PM
DenzComp's Avatar
You're F'd.
Old May 18, 2007 | 05:39 PM
CRXed's Avatar
Default Re: (DenzComp)
Had extreme trouble with mine one day.
Put a clamp on the silencer, tied that to my friends car, vroom vroom and ohhhhh it came out.
Old May 18, 2007 | 08:20 PM
iheartmyh0nda's Avatar
Default Re: (CRXed)
just remove the whole exhaust and get something new lol, im jk, good luck to you man
Old May 19, 2007 | 03:03 AM
DOHCturbo02's Avatar
lube that thing up with WD-40 inside and out or better yet, use LPS-2 and let it soak for a good 10 minutes. I attached a 4 inch metal rod (4 1/2 inch tip) attached with a chain, stuck it inside my silencer and pulled like crazy till the sucker came out! Good luck
Old Jun 13, 2007 | 05:59 PM
innes887's Avatar
slide hammer with the pilot bearing removal tool on the end.
Old Jun 13, 2007 | 06:21 PM
janz3n's Avatar
Default Re: (innes887)
or you can drill a tiny holeand use a screw in slide hammer.. or you can take the fart can off and get something els.
Registered user
Welding / Fabrication
Nov 16, 2016 02:53 PM
lspecz
Feb 28, 2007 04:34 PM
.M.
Mar 13, 2005 10:02 PM
csufweed
Aug 11, 2002 06:44 AM
JL 74
Oct 4, 2001 06:51 PM
