Suspension/Brake Setup
What's the best suspension and brake setup for an '01 Civic LX?
For suspension, I'm thinking of KYB AGXs, TEIN S-Techs, ST sway bars, and unsure for strut bars.
For brakes, I'm thinking of ss brake lines and Brembo front rotors. Is it worth it to do a rear-disc conversion? If so , where's the best deal on the net?
Thanx guys!
Thanx guys!
The "Best"? Well, that's an entirely too open question. You didn't specify what the car would be used for. For daily driving, Tein S-Tech's are ok, but on the track they're too soft and KYB's aren't the damper I would go with. Maybe Moton remote reservoir dampers with Swift custom springs and Hotchkis camber plates. That would be a nice setup. Of course, you're looking at about $8,000 in just your spring/damper setup.
Same goes with your brakes. It's all entirely dependent on what you're doing with your car. And, there's no such "deal" for a rear disc brake swap. You'll need to go through the classifieds and junkyards to find a swap.
Autozone replacement rotors, Hawk HPS's (for low brake dust), and stainless brake lines will suffice for stopping power.
I, personally, wouldn't buy anything less than Tein Flex's, as far as Tein suspension options go. But, if you want a track-ready suspension, go with either a decent Ground Control setup or a pre-built coilover, like F2's or something of the like.
i had the xbrace and i took it off to stay in my class i honestly prefer not having one. and as for a suspension set up im running the tein super street coilovers with the pillow ball mounts and i think its a great setup for daily driving/autocross and mild track use.
as for brakes im currently running hawk autocross pads on the front, ill let you know what i think about the rear disc conversion after i put it on. i paid 400 bucks for mine and its coming with everything i need. the junkyard i went through is even throwing in the ebrake cable for free lol
int3gr4vtec
Jun 22, 2007 01:08 PM
ArchAngel Sabastian
Nov 11, 2005 09:23 AM
Shocka1998LX
Aug 18, 2004 06:19 AM
SteveeeO
16
Jan 22, 2003 01:31 PM
