clutch fork questions!
Old May 18, 2007 | 08:58 AM
clutchmaster2005's Avatar
Default clutch fork questions!
when i pull on the clutch fork with my hand.. should i feel alot of resistance as if i couldnt push the pressure plate fingers? i know that the cable on the fork and you foot on the clutch makes enough mechanical advantage to push the fingers but should i not be able to pull up on the fork with just my hand?
Old May 18, 2007 | 10:44 AM
Slurp56's Avatar
Default Re: clutch fork questions! (clutchmaster2005)
There will be alot of resistence. You will be able to move the fork pretty freely until the bearing hits the pressure plate springs, then it will stop. If you use both hands and REALLY pull up on it, you should be able to get it to move.
Old May 18, 2007 | 11:19 AM
4g hatch's Avatar
once the bearing hits there should be a lot of resistancde you shouldnt be able to just grab it and move. in other words WHAT HE SAID!!!
CDizzle_996
Transmission & Drivetrain
Jan 26, 2013 12:32 PM
94DB8
Sep 9, 2010 01:36 PM
turbosivtec
Feb 8, 2009 02:26 PM
trianglegreg
Jun 10, 2006 12:02 PM
nexus da9
May 10, 2004 04:54 PM
