Code 16: Injectors
Old May 18, 2007 | 06:43 AM
rtnlsltn's Avatar
Default Code 16: Injectors
Finished my GSR swap and im getting a code 16 from my p28 in my CRX. The injectors are getting 12.4 volts, as i removed the resistor box as directed from Rywire. The other wire on the injector is getting 3.18v. Currently my fuel is not getting past the injectors and backing up in the fuel rail. I modified my obd0 clips to fit obd1 with a simple cut on the corners of the clips, and they fit perfect. From what i can see the contact is being made although it is hard to test. I have plenty of fuel pressure, but its just not going anywhere. Any ideas on what to check? Previously i was running a B16A ECU with a ls-vtec and some piggybacks. I am now swapped to obd1 with the p28 un-modified. I need to get my car running by the weekend...long story but if anyone could help that would be awesome.
lamesa
Jan 2, 2015 04:06 AM
lsvSwagg
Jan 29, 2013 07:46 AM
axtran
May 11, 2006 11:48 AM
TwoKSiR
Oct 19, 2004 04:06 PM
JDM Jimmy
Mar 14, 2004 01:35 PM
