Need Help Cel #9
Old May 18, 2007 | 05:23 AM
LiL JoN's Avatar
Default Need Help Cel #9
i have a 89 civic with a D16a6 motor with msd 6al w/blaster coil was working fine...all of a sudden threw a code 9 studders at low rpm ... how do i fix this problem
THANKS help please
Old May 18, 2007 | 10:14 AM
LiL JoN's Avatar
Default Re: Need Help Cel #9 (LiL JoN)
some one
Old May 18, 2007 | 02:27 PM
LiL JoN's Avatar
anyone
Old May 18, 2007 | 04:55 PM
LiL JoN's Avatar
Old May 18, 2007 | 07:15 PM
EF_LSVtec's Avatar
Code 9 - No. 1 Cylinder Position Sensor
It's the third sensor in the dist., and it detects the position of the No. 1 Cylinder, as the base for the Sequential Injection. It can also be located on the camshaft of DOHC engines.
CYP sensor is mounted on the exhaust cam on the ZC.
If the dist. base bearing starts failing, it will heat the sensor(s) up, destroying the magnetism thus causing a code(s). It will lose 10% of it's strenght, each time it is heated up to 170 degrees plus.
In most cases, replacing the distributor is the only alternative. Especially if the bearing has failed.
Honda does don't stock the bearing by itself, but other after-market compaines are said to have one.
If you have problems starting the engine, or drivability after the install check your cam aligment. The seizing bearing might have caused it to jump a tooth/notch or two. From the extra drag due to the bearing failing.
Taken from: http://www.geocities.com/chipman_13/ecu.html
Old May 19, 2007 | 10:31 AM
LiL JoN's Avatar
Default Re: Need Help Cel #9 (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">Code 9 - No. 1 Cylinder Position Sensor
THAnKS
2poor2tune
Jun 23, 2006 01:38 PM
Tippyman
Mar 10, 2006 06:03 PM
saccord
Nov 21, 2005 07:24 PM
CrxSiRyder
Jan 25, 2005 11:37 AM
Krakkles
Nov 24, 2004 09:29 PM
