Fog Light Switch
i know i searched...got many answers....but have 1 ? is there any other fog light switch that would fit in the center console of my 94 right next to the emergeny lights.......bc i found a couple but r really expensive....any info would help.....thnx
the stock replacement is pretty expensive.
I've seen some forums where some people get the hazard switch and put it there. Of course you need to do some wiring. Then they get a fog light sticker symbol from other models and put that on and take the hazard sticker off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oranginal »</TD></TR><TR><TD CLASS="quote">the stock replacement is pretty expensive.
I've seen some forums where some people get the hazard switch and put it there. Of course you need to do some wiring. Then they get a fog light sticker symbol from other models and put that on and take the hazard sticker off.</TD></TR></TABLE>
I removed all my cruise control components since it is not working anyway, and converted the cruise control button in the car into the fog light switch, do you know where can I get "fog light sticker symbol" from?..
I took a look at my fog light switch in my integra part car and it looks liked it is painted on and not sticked on...
I used a PILOT fog light and its harness, but I mounted the fog light inside the bumper just light the factory (lot of metal fabbing for the mount and cut out the plastic), I am going to fab a cover for the front this weekend. I tapped into a light green wire behind the cruise control button on the dash into my PILOT relay (bypass the pilot's switch) to get my fog light to turn on and off with the cruise control button. This should work for all the people who use just the factory fog light with external wiring harness and have an unused cruise control button....
I was hoping it would have worked for the oem wiring/foglihgts. I want to be able to have the fogs come on with parking lights, lows, and go off through the relay when I click high beams on. I don't want to have to turn th lights on and off through a different switch when the high beams come on.. I'll just find how that one guy used a BMW foglight switch from a junkyard or something instead..
