pistons
Old May 17, 2007 | 08:23 PM
junior_tm's Avatar
Default pistons
i have a d16z6 vtec and i was wondering what pistons should i put?
also i'm putting a turbo with 5-8 psi not sure yet please let me know
Old May 17, 2007 | 08:29 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: pistons (junior_tm)
if the compression is good across the board and a leakdown test shows fine, low boost like that will be fine for your stock pistons.
Old May 17, 2007 | 08:31 PM
Team RS2's Avatar
w/e you want, since you're in there might as well get a better piston/rod setup,
while you're building buy new honda bearings, the weak point of the Z motor is the ring lands and rods
some people run vitara's with eagles and some run higer aftermaret ones its all up to you
but if you were to do a full rebuild honda engines (one of the reaons) are so realible becuase of the bearing setup, head desighn and block desghn dont expletive with this or if you do expletive with it right
random fact NASCAR engines/ NASCAR engine builders prefer honda oem bearings to any other aftermarket/oem supplier
Old May 17, 2007 | 09:04 PM
1995Civic's Avatar
Default Re: pistons (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">if the compression is good across the board and a leakdown test shows fine, low boost like that will be fine for your stock pistons.</TD></TR></TABLE>
This is all you need to know right here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">w/e you want, since you're in there might as well get a better piston/rod setup</TD></TR></TABLE>
He's not going to be digging in there unless he absolutely has to.
For that amount of power, there will be no reason to...unless his compression test shows that his pistons/rings are shot.
Old May 17, 2007 | 09:05 PM
Ek Forever y0!
Default Re: pistons (1995Civic)
Not worth the hassle when he wont benefit from it unless he's making more than 230whp.
short of 250whp it's really just insurance. But d-series are a dime a dozen, so blowing one Up isn't a big deal.
Old May 17, 2007 | 09:14 PM
Team RS2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Not worth the hassle when he wont benefit from it unless he's making more than 230whp.
short of 250whp it's really just insurance. But d-series are a dime a dozen, so blowing one Up isn't a big deal.</TD></TR></TABLE>
im surely glad i got turbo advice from you
Rockin the stock civic for now. I like to do multiple mods at once.
Old May 17, 2007 | 09:16 PM
Ek Forever y0!
Default Re: pistons (Team RS2)
A lot of the most knowledgeable people on here have stock cars.
Hell some don't even own hondas. Your reasoning of me owning a stock car as being correlative of me not knowing anything about hondas is juvenile and illogical.
Old May 17, 2007 | 09:19 PM
Team RS2's Avatar
post some deatiled information about what you have done honda or not and ill withdrawl my comment and change my opnion
Old May 17, 2007 | 09:22 PM
turbociviccoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">post some deatiled information about what you have done honda or not and ill withdrawl my comment and change my opnion </TD></TR></TABLE>
he is knowledgeable and knows what he is talking about or asks. he has my vouch. never seen you on this site so does that mean "you dont know anything?"
i daily drive a stock hatch so put your money where your mouth is.
Old May 17, 2007 | 09:24 PM
Ek Forever y0!
Like swapping a y8 tranny, new clutch/flywheel, tb and ipsb, axles, y8 manifold, shifter, tein SS on my brothers dc2, a mini-me for my friend in Glendale,
Welding two exhausts up for two people at tokyo speed pros. Welding an ebay header back together that's been going strong for 5,000 miles, shortening shift linkages, and wiring new headlight harnesses.
Old May 17, 2007 | 09:30 PM
Eran's Avatar
HT White Ops
Some things that make you sound petty and immature:
Saying "oh yeah, I'd like to see your piece of ****" when someone criticizes your car.
Saying "you drive a stock car" when someone corrects your technical information.
Saying "you need to go get laid and get a life" when you're criticized in any way shape or form.
Old May 17, 2007 | 09:33 PM
Team RS2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Like swapping a y8 tranny, new clutch/flywheel, tb and ipsb, axles, y8 manifold, shifter, tein SS on my brothers dc2, a mini-me for my friend in Glendale,
Welding two exhausts up for two people at tokyo speed pros. Welding an ebay header back together that's been going strong for 5,000 miles, shortening shift linkages, and wiring new headlight harnesses.</TD></TR></TABLE>
look back on what you are bragging about when you get a project
Old May 17, 2007 | 09:36 PM
1995Civic's Avatar
Dude...you are a jackass!
Ek forever guy will school your *** in anything that has to do with a Honda!
What is your reasoning for saying he doesnt have knowledge? He is ABSOLUTELY RIGHT about not needing to change out the pistons/rods until you are up to about 220whp.
Go ahead and question me, i DD a boosted D....for over a year now, and im almost done building a D for 400+ whp.
Old May 17, 2007 | 09:38 PM
Team RS2's Avatar
he is right on the pistons im not worrued about that, he knows what pissed me off and what he is DOING NOW to **** me off, he can stop if he does what i requested, im already ignoring ERAN
Old May 17, 2007 | 09:40 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">he is right on the pistons im not worrued about that, he knows what pissed me off and what he is DOING NOW to **** me off, he can stop if he does what i requested, im already ignoring ERAN </TD></TR></TABLE>
What an effective way to solve your problems. Very adult-like.
Eran's Avatar
HT White Ops
On flaming and ignoring the people that help out most in this forum.
Next thing you know, he'll call Bense, Archidictus, Padawan, and pdiggitydogg trolls.
Old May 17, 2007 | 09:41 PM
1995Civic's Avatar
Ok, now i just dont understand what you're saying...
What is the reason you called him out the way you did?
Old May 17, 2007 | 09:42 PM
Ek Forever y0!
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote"> On flaming and ignoring the people that help out most in this forum.
Next thing you know, he'll call Bense, Archidictus, and pdiggitydogg trolls.</TD></TR></TABLE>
I know, you, NOFX, and I are already on the list.
but I bet I'm the numba one troll
Old May 17, 2007 | 09:43 PM
Team RS2's Avatar
between me and him, but bense is very helpful, idk who the other 2 are, but im done talking about it
Old May 17, 2007 | 09:44 PM
Default Re: (ek forever guy)
but I bet I'm the numba one troll </TD></TR></TABLE>
what the heck you do to get this guy pmsing adam...lol lets get this **** locked
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">between me and him, but bense is very helpful, idk who the other 2 are, but im done talking about it </TD></TR></TABLE>
But oddly enough, you're the one who brings it up in every single thread.
Old May 17, 2007 | 09:45 PM
Ek Forever y0!
Default Re: (turbociviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">
that the heck you do to get this guy pmsing adam...lol lets get this **** locked</TD></TR></TABLE>
I can't even remember, I get in nub fights all the time. They just can't handle my H-T extendable baton of logic/common sense.
IBTL
Old May 17, 2007 | 09:49 PM
muhaMan's Avatar
get the Vitara Pistons made by YCP, ive heard VERY GOOD things about those pistons, u can get a set for $150
Old May 17, 2007 | 09:55 PM
Team RS2's Avatar
Default Re: (muhaMan)
he deosnt know how
Old May 17, 2007 | 09:56 PM
Eran's Avatar
HT White Ops
Really, at 5-8psi, you don't need to upgrade any internals. Just get a chipped ecu, spend a couple bills getting a credible dyno tune, and run all day long.
D-series are bulletproof .... just ask Mike from Whiplash.
