What to expect from DPFI to MPFI
Hello everyone-
I want to do a motor swap in the near future. Before I get into buying anything too big, I'd like to first convert to MPFI. I all ready know how it's done, and what I need. I only have one question about the swap. I know I need the PM6 ECU, but it is 5 speed. I have the standard hatch with the 4 speed. Will this be a problem?
After the swap, what should I expect? Slightly higher HP? MPG? Will my D15 respond better to bolt-ons?
Any information would be greatly appreciated.
Thanks in advance,
-Dennis
Thanks in advance,
-Dennis
what? you can do a mpfi swap and retain the dx auto trans,
either use an auto pg7 ecu or use a standard trans mpfi ecu and an rpm activated switch to turn on the lock up converter
all an automatic obd0 ecu does differently than a standard ecu is turn on/off the lock up solenoid for the torque converter, the lock up does not need to be wired up but the car is more efficient on fuel mileage if it is due to the fact that the rpms drop about 600 since the converter isnt slipping (in high gear)
Thanks everyone. Should my MPG increase or decrease? I'm seen people saying I'll get better gas mileage, and people saying the opposite. Anyone do this and actually know for sure?
Thanks again.
Thanks again.
i would actually say you will see an increase in gas mileage. ive had both multiport an dual point injection vehicles. all of my multiport crx and civic got better gas mileage than the dual points.
