People with a milled H22A?
Old May 17, 2007 | 07:38 PM
Mydogisgone's Avatar
Default People with a milled H22A?
Are there people here who milled there H22a?
And how much did you milled your H22A? And what horsepower did you get with it?
Old May 18, 2007 | 05:49 AM
Default Re: People with a milled H22A? (Mydogisgone)
nobody?
Old May 18, 2007 | 11:34 AM
GoldLudeRay's Avatar
also wondering too
Old May 18, 2007 | 12:58 PM
RaceCarRyne's Avatar
Default Re: (GoldLudeRay)
too vague.. search
Old May 18, 2007 | 01:39 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mydogisgone &raquo;</TD></TR><TR><TD CLASS="quote">Are there people here who milled there H22a?
Milled how much?? and are you running stock cams? ever plan to??
i milled my head .050 and it ripped! stock cams, stock ports, hotshot header, ran 12.0 1/4 in a 4 door EG lightened to 2200 lbs, but still fast. BUT and heres the important part, i had stock cams,
Now i did the same to my new setup with skunk 2 stage 2 cams and bent all the valves on the first pass down the street..... so i'd say mill it if you never plan on running anything but stock cams.. but if not then you have to be REALLY careful because the piston to valve clearance is not very much! as my bent *** valves can tell you. its up to you. it does help but i'd avoid it if you ever plan on going with anything bigger than stage 1 cams.
Old May 18, 2007 | 02:24 PM
Default Re: People with a milled H22A? (h22crxpwr)
ah i see.
So 0.050" is oke when i'm going for stock cams?
I have now my head about 0.026398" Milled.
So i'm save when i'm going to run with stock cams?
And how will it go when i go for Crower stage 2 cams?
when i use those, will it be safe? our do you guys say i need TO clay it then?
At least thank you to say that the engine will be oke when you did a 0.050" mill and it runned. SO i certainly save with my 0.026" mill.
Tommorow i'm going to start my fresh builded H22A
Old May 18, 2007 | 10:15 PM
what is the max milling spec on the h22
Old May 19, 2007 | 07:01 PM
Lubo_25's Avatar
i really dont know why ppl shave heads to raise compression...do not play with honda sizes buy pistons and build it properly...the max. honda spec is .008" as per my prelude service manual...
Old May 20, 2007 | 10:17 AM
why do we hear about people milling way past spec then
Old May 20, 2007 | 10:39 AM
117's Avatar
117
Default Re: (Lubo_25)
On which page did you find this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">i really dont know why ppl shave heads to raise compression...do not play with honda sizes buy pistons and build it properly...the max. honda spec is .008" as per my prelude service manual...</TD></TR></TABLE>
My understanding is that there are a number of indicators that show the maximum material that can be removed on both the head and the block. They look a bit like recessed "dots" (for lack of a better word). How else would you optimize squish if you didn't mill the head?
My block has been decked around 0.003" to 0.005", and the head was milled to get squish around 0.045" (it'll be different for every cylinder, unless you have the quench pads in the head machined to the same height) with a stock head gasket. There was pleny of piston to valve clearance with stock cams, but I don't know what the clearance would be like with aftermarket cams. I used adjustable cam gears to get the cam timing back to stock. The engine put down 204WHP with mostly stock internals (stock cams, stock pistons, stock rods, stock valves, etc). It's on a track car though, so there are a few other tweaks here and there.
Old May 21, 2007 | 11:08 AM
h22crxpwr's Avatar
because its cheap and easy way to bump compression and most of these people with hondas are broke *** people who want to build their car with virtually no expense.. , however it leads to other problems, like piston to valve clearance....... but you wanted an answer..
mozzandherb
Jun 22, 2011 07:55 AM
arun92lude
Sep 5, 2010 01:00 PM
BIG T
Mar 16, 2008 07:52 PM
dpine
Sep 12, 2006 05:43 AM
HondaIntegraR
Jul 14, 2005 11:24 AM
