b16a in my crx dx
Old May 17, 2007 | 07:31 PM
egcivic_ny's Avatar
Default b16a in my crx dx
i have 2 problems. 1 my clutch cable catches too high, which cable should i be using? 2 is there any way to get around hooking up the knock sensor?
Old May 23, 2007 | 06:42 AM
egcivic_ny's Avatar
anyone? please
Old May 23, 2007 | 07:30 PM
wens_crx's Avatar
Default Re: (egcivic_ny)
what do u mean ur clutch is catching high??
Old May 23, 2007 | 07:39 PM
iheartmyh0nda's Avatar
Default Re: (wens_crx)
catching high as in, the release point on your clutch pedel is too high...or what?
Old May 23, 2007 | 08:18 PM
slow_rex_will's Avatar
Default Re: (PleaseKeepOffDunes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PleaseKeepOffDunes &raquo;</TD></TR><TR><TD CLASS="quote">catching high as in, the release point on your clutch pedel is too high...or what?</TD></TR></TABLE>
have you tried adjusting your clutch cable?
Old May 23, 2007 | 08:21 PM
bobbycreek's Avatar
u
Old May 23, 2007 | 08:24 PM
Default Re: (bobbycreek)
u? am i missing something on this post?
Old May 23, 2007 | 08:39 PM
egcivic_ny have you tried adjusting your clutch cable!
Old May 23, 2007 | 09:22 PM
crxrocket's Avatar
why would you want to get around wiring up the knock sensor ? it is only 1 wire. try adjusting ur clutch. you have 2 adjusting points. 1 on tranny & 2 on ur peddle. good luck.
Old May 23, 2007 | 10:32 PM
4g4db16's Avatar
Default Re: (crxrocket)
nope no way of getting around it, unless you get a chipped ecu that eliminates the knock sensor
PIC Performance
Mar 26, 2005 02:54 PM
doublethink
11
Dec 5, 2004 03:57 PM
asmallsol
Aug 9, 2004 08:06 AM
jondancer
Jun 9, 2003 02:57 AM
