90 Civic DX Wont Start
Old May 17, 2007 | 06:45 PM
PredatorTypeS's Avatar
Default 90 Civic DX Wont Start
It cranks but usually never turns on. If I get a jump start, it turns on. And it usually turns on when it's cold. But when the weather is hot, or after taking it for a drive, it most likely wont turn on unless it gets a jump start. I already got the alternatror, battery, and starter checked and they're good. I also changed the spark plugs 3 months ago. I'm out of ideas on what could be wrong....
Old May 17, 2007 | 10:03 PM
Efbluevtec's Avatar
Default Re: 90 Civic DX Wont Start (PredatorTypeS)
check your iacv on the intake manifold or maybe your fuel pump is not priming. usually the fuel pump relay goes out and it doesnt prime gas to injectors.
Old May 17, 2007 | 10:27 PM
RCautoworks's Avatar
Default Re: 90 Civic DX Wont Start (Efbluevtec)
Pull the spark plugs, see if there covered in oil or fuel, after you crank it. If you don't smell any fuel, look into the main relay.
Old May 18, 2007 | 12:26 AM
pdotjones's Avatar
Default Re: 90 Civic DX Wont Start (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">look into the main relay.</TD></TR></TABLE>
bpotter05
56
May 15, 2012 01:02 PM
hamburgler
Aug 21, 2011 10:23 AM
usdmEHboy
12
Jan 17, 2011 04:14 PM
Arthas
Sep 2, 2010 06:42 AM
.Noah Fecks
11
Aug 9, 2003 08:06 PM
