Need help w/ Rear Engine mount.. extremely frustrated.
Here's the deal. I have a 90 CRX DX.. the previous owner attempted a motor swap (b18a1) and didn't know ****.. i'm in the process of installing a rear engine mount bracket.. the mount is bolted down.. the bracket is not.. I can't get the ****** positioned right and i'm about to throw my prybar through my goddamn wall. I dont have a goddamn engine hoist either.. all i have is a big *** gorilla bar.. and scarred up ******* knuckles.. any help would be splended. Thanks -Matt-
try putting a jack under the eng / trans also take the eng mount bolt out it's tappered and will be easier to get lined up than the one that bolts down to the subframe.
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
make sure the rear mount is bolted to the bolt holes closest to the driver side
Jacking up the motor should do it, its just going to take some time. Go grab a buddy and have 1 of you trying to get the bolt in and one jacking it up. Your just going to have fight with it till it gets in its hole
yeah, the problem with jacking the motor up, is I have an ef mount on the drivers side holding the motor in.. and I hate to take it off because i only have jacks under the motor.. its just scary.. dont want to f' anything up.
pushinlsteg
May 31, 2005 07:27 PM
CristalCleanCivic 97 EX
Aug 8, 2003 10:39 AM
