What's the difference between P54 and P7J compressor bracket??
I have searched and most was wtb/fs topics. I know P54 are from 95 delsol V-TEC nd P7J are from CRV don't know what year. Price are $40 difference at Majestic, delsol one cost $105 and I enter a 99 crv $63. I remember both will work for d-series compressor, and some wtb topic people prefer the P54 over P7J. Beside price difference and of course the car model, do both bracket work??
You cannot keep power steering with the CR-V bracket, so unless you have P/S get the Cr-V bracket due to its cheaper price.
What are the part numbers for both of these parts?
When I goto Majestic, I do not know what I am looking for, as the pictures are not working for me.
38930-P7J-000 CRV Bracket
38930-P54-000 Del Sol Bracket
I am using the p7j on my eg with gsr swap.. All bolts lines and fits perfectly
As long as I dont have to take out any more Metal Gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">You cannot keep power steering with the CR-V bracket, so unless you have P/S get the Cr-V bracket due to its cheaper price.</TD></TR></TABLE>
not true. If you have a b18 and want to keep PS then the p7j or the p54 will work. If you have a b16 and want to keep PS then only the p54 will work. If u have a b18 or b16 and want to eliminate PS altogether then get the p7j, its way cheaper than the p54.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">
not true. If you have a b18 and want to keep PS then the p7j or the p54 will work. If you have a b16 and want to keep PS then only the p54 will work. If u have a b18 or b16 and want to eliminate PS altogether then get the p7j, its way cheaper than the p54.</TD></TR></TABLE>
not exactly true. i currently have B16 and i have P/S and A/C with the P7J bracket.
Damn already bought the p54, and I have a b18, o well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">You can keep PS with both brackets. I say buy the cheaper on. </TD></TR></TABLE>
Bingo!
If anyone wants, I can supply pictures of the p7j, on b18, with P/S
(philosofy1 can probably provide for b16)
Buy the p7j - its ridiculously cheaper
Bingo!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
Bingo!
Buy the p7j - its ridiculously cheaper</TD></TR></TABLE>
Where were you guys a week ago, I could of save some money
. Like the last post I already bought the bracket, good info to know now. Thanks guys
Bingo!
Right here:
https://honda-tech.com/zerothread?id=1985508
(it was exactly last week, in fact
(but...ive been saying p7j on b18 = ok for like...a year now (?))
)(but...ive been saying p7j on b18 = ok for like...a year now (?))
so if i take a obd1 b18c1 gsr motor out of a 94 integra gsr, and install it into a 95 civic ex sedan, and want to keep my d series ac compressor and lines, and power steering ill need the P54 <FONT SIZE="5">OR</FONT> p7j bracket????????
either one will work? how about the torque mounts? do i need to use different torque mounts depending on which a/c bracket i use???????
and since i will be using the d series compressor, which ac belt and ac tensioner will i need to run?
Modified by MeanGreenMachine at 1:35 AM 5/10/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">so if i take a obd1 b18c1 gsr motor out of a 94 integra gsr, and install it into a 95 civic ex sedan, and want to keep my d series ac compressor and lines, and power steering ill need the P54 <FONT SIZE="5">OR</FONT> p7j bracket????????
for an answer
for an answer
yes the P54 or the p7j will work. im currently using the p7j on my b18c-R with power steering and a d series compressor in my 93 si. I did have to get a pwr steering pump and brackets from an integra though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fortymcpants »</TD></TR><TR><TD CLASS="quote">yes the P54 or the p7j will work. im currently using the p7j on my b18c-R with power steering and a d series compressor in my 93 si. I did have to get a pwr steering pump and brackets from an integra though.</TD></TR></TABLE>
thank you sir!
thank you sir!
is this what your talking about??
Use a DOHC Del Sol-P30 P/S top mount and P54 P/S lower mount and you will be able to use your stock P/S pump....
and as far as the ac compressor goes, which ac bracket will i need if i swap a b series motor in a obd2 96-00 civic chassis?
p54 <FONT SIZE="5">OR</FONT> p7j
, did everything else.
