3 Different ECU's FS Prelude SH 97-01 and two 2nd gen Integra computers
The two Integra ECU's are used.
The OBD 1 ECU has the part number: 37820-PR4-A11 It was made for a 92-93 Integra LS (non-vtec) with manual transmission. $35
The OBD 0 ECu has the part number 37820-PR4-A10 It was made for a 90-91 Integra LS (non-vtec) with manual transmission. $40
Someone please correct me if I'm wrong, but the OBD-0 ECU should work with a 89-91 Civic. And the OBD-1 ECU should work with 92-95 Civic's as well.
The OBD-0 ECU....
The OBD-1 ECU...
Modified by WuWarrior at 9:23 PM 6/20/2007
The OBD-0 ECU....
The OBD-1 ECU...
Correct:
OBD0 PR4 will work in any 88-91 Civic or 90-91 Integra
OBD1 PR4 will work in any 92-95 Civic or 92-95 Integra
Both are non-VTEC and both can be socketed and programmed.
GL to you!
GL to you!
