Tire Selection
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Which tires should I get?
This depends on what you're looking to get out of the tire. Make a new topic and tell us what you intend to use it for. In that topic, make sure to answer the following questions:
- What kind of car you have (year, model, version)
- What size wheels you have
- How the tires will be used (daily driving, autocross/track/dragstrip)
- What kind of weather the tires will be used in (dry, rain, snow)</TD></TR></TABLE>
Car: 2001 Honda Civic EX (Coupe) w/ engine swap and heavy duty suspension modification.
Wheels: 16x7 +47
Usage: Spirited Daily Driving (on some weekends it will drive on mountainous "touge style" roads)
Weather: Typically mid-80's, med. humidity, with occasional rain showers. They will be primarily Warmer season tires, they won't see snow or ice.
PS. I was looking at Kumho's, due to their $40 off deal, but I won't stick to them just because they're cheap. I'm looking for a tire that can last long as well. Also, I did get burned on my last set of Kumho's. Ecsta Supra 712's. I was appalled at their performance, to say the least.
I do know that I'd like to stick in the 205/50/16 - 225/45/16 range for both comfort, and previous experience.
Wheels: 16x7 +47
Stock size on your car is 185/65-15. For your 16" wheels, 215/50-16 is a dead-on match in diameter. I recommend the Avon Tech M500, $81/tire in that size at the Tire Rack. This tire is actually even slightly better than the Kumho SPT and Yokohama ES100, neither of which is available in that size. (FWIW, the SPT is available in 205/50, 1.6 percent smaller than stock, for $76; even with the rebate on the Kumho, the price difference isn't all that much.) And I would avoid going any wider than 215, for fear of rubbing. So the Avon is what I would get.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">Stock size on your car is 185/65-15. For your 16" wheels, 215/50-16 is a dead-on match in diameter. I recommend the Avon Tech M500, $81/tire in that size at the Tire Rack. This tire is actually even slightly better than the Kumho SPT and Yokohama ES100, neither of which is available in that size. (FWIW, the SPT is available in 205/50, 1.6 percent smaller than stock, for $76; even with the rebate on the Kumho, the price difference isn't all that much.) And I would avoid going any wider than 215, for fear of rubbing. So the Avon is what I would get.
I've got pulled fenders, bud.
I've fit 225's on 16x7.5 +32's.
I did rub on the inner fender with some +45's, though. But, I've got an assortment of spacers, so it's not that big of a deal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">Who's Avon Tech's manufacturer? Or is it just Avon Tech. I'm just trying to brush up on the manufacturer's details.</TD></TR></TABLE>
Avon Tyres
Tirerack is a supplier
Avon Tyres
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">
Avon Tyres
I knew of their main branch. I was just seeing if any larger corporation owned the franchise. Thanks, though.
Avon Tyres
I knew of their main branch. I was just seeing if any larger corporation owned the franchise. Thanks, though.</TD></TR></TABLE>
From their website: "Avon Tyres is owned by the Cooper Tire & Rubber Company."
From their website: "Avon Tyres is owned by the Cooper Tire & Rubber Company."</TD></TR></TABLE>
My buddy Ralph said that as well. Thanks.
My buddy Ralph said that as well. Thanks.</TD></TR></TABLE>
Excellent, Buddy Ralph and the company's official website are both in agreement, one could not ask for more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC_Rikimaru »</TD></TR><TR><TD CLASS="quote">i like the falkin zieks. good all around cheap. last longer then the kumho. had both.</TD></TR></TABLE>
The Ziek 512's are notorious for weak sidewalls. I'll pass.
Are you referring to the Kuhmo SPT? The Falkin Ziex is a shitty all season tire, the Kuhmo SPT is a serious summer tire. Apples and oranges. If all you care about is longevity than perhaps it was a good tire for you however a lot of other people want more out of their tires and are will to sacrifice a bit of longevity for it.
Are you referring to the Kuhmo SPT? The Falkin Ziex is a shitty all season tire, the Kuhmo SPT is a serious summer tire. Apples and oranges. If all you care about is longevity than perhaps it was a good tire for you however a lot of other people want more out of their tires and are will to sacrifice a bit of longevity for it.</TD></TR></TABLE>
Strongly agreed! Also the Ziex 512 are going to be discontinued very shortly! About time Falken gets rid of that shitty tire
mattmatt
Jan 3, 2006 10:39 AM
